VMserver on Vista 64bit
Beitragvon continuum » 04.10.2007, 01:13
Beitragvon I.P. » 08.10.2007, 11:10
der link funzt net ;)
ich bekomme lediglich eine "Die Webseite kann nicht angezeigt werden" meldung, das thema ist für mich aber aktuell. gibts eine andere infoquelle?
Beitragvon continuum » 08.10.2007, 14:44
VMware hat die Forums-software upgedatet und vermurkst - vielleicht spaeter wieder ..
Beitragvon continuum » 08.10.2007, 19:29
Mann weiss ja nie wielange VMTN diesmal online ist :D - deswegen ...
Goal: Get VMWare Server 1.0.4 installed and working on Vista x64 Ultimate Edition
Assuming you have updated Windows Vista x64 with the latest security updates, patches, etc from Windows Updates, don't waste your time trying the BCDEdit or Group Policy Editor options mentioned in many discussions - they seem to have no effect if your machine is up to date patchwise.
The directions below are the only ones that have worked at all for me:
Prior to installing VMWare Server, reboot your machine and hit "F8" on startup, then select "disable driver signing requirements".
Install VMWare Server - ignoring messages about "Windows requires a digitally signed driver" for vmx86.sys etc.
Reboot machine, again pressing "F8" and selecting "disable driver signing requirements"
Fire up VMware console - you should be able to select "Local Host" as the machine to connect to.
Don't ever restart Windows again - if you do, hit "F8" and choose "disable driver signing requirements". A much better option would be to "Suspend" or "Sleep".
Assuming you are running Vista with User Account Control enabled, and you didn't enter the VMware serial number during installation, you MUST start VMWare Console "As Administrator" by right-clicking the icon, and selecting "Run As Administrator" otherwise you won't be able to install the VMware Serial Number into the system registry, and you won't be able to power on any VMs.
Beitragvon Flip » 06.02.2008, 09:46
Wird bei 64Bit Maschinen, mehr als die 3,6GB Arbeistsspeicher unterstützt und wie viele CPU´s werden beim GSX unterstützt. Kann ich wenn ich 2xQuadcore auf meinem Windows-Host einsetze auch die 8 CPU´s nutzen?
Keiner einen tipp :oops:
Beitragvon riedochs » 18.05.2008, 17:07
Hallo
genauso wie oben beschrieben habe ich VMware Server 1.0.5 installiert, allerdings endet jeder Versuch VMware zu starten in einem Bluescreen: 0x0000004D NO_PAGES_AVAILABLE
Allerdings habe ich SP1 für Vista64 installiert. Jemand ne Idee?
riedochs
Beitragvon continuum » 18.05.2008, 18:25
Betreibst du vielleicht Vista ohne pagefile ?
Beitragvon riedochs » 19.05.2008, 16:28
Ja, pagefile ist deaktiviert. Bei 6GB Ram hielt ich das nicht für nötig
riedochs
