PSOD bei Passtrough
Alles zu vSphere 8
PSOD bei Passtrough
Beitragvon MarroniJohny » 02.06.2023, 03:10
Seit ich auf ESXi-8.0U1-21495797-standard bin, lässt sich mein FreePBX nicht mehr starten. Wenn ich die Asterisk Karte per passtrough angehängt habe und die VM starte, macht der Host einen PSOD:
Ich habe auch versucht, alle Einträge in der vmx Datei bezüglich PCI zu löschen, und die Karte neu hinzufügen. Brachte auch nicht wirklich was.
So sieht die vmx Datei z.Z. aus:
.encoding = "UTF-8"
displayName = "FreePBX"
config.version = "8"
virtualHW.version = "19"
vmci0.present = "TRUE"
floppy0.present = "FALSE"
memSize = "2048"
bios.bootRetry.delay = "10"
powerType.suspend = "soft"
tools.upgrade.policy = "manual"
sched.cpu.units = "mhz"
sched.cpu.affinity = "all"
vm.createDate = "1639885713948608"
scsi0.virtualDev = "pvscsi"
scsi0.present = "TRUE"
sata0.present = "TRUE"
usb.present = "TRUE"
ehci.present = "TRUE"
scsi0:0.deviceType = "scsi-hardDisk"
scsi0:0.fileName = "FreePBX-000001.vmdk"
sched.scsi0:0.shares = "normal"
sched.scsi0:0.throughputCap = "off"
scsi0:0.present = "TRUE"
ethernet0.virtualDev = "vmxnet3"
ethernet0.networkName = "101"
ethernet0.addressType = "static"
ethernet0.uptCompatibility = "TRUE"
ethernet0.present = "TRUE"
sata0:0.deviceType = "atapi-cdrom"
sata0:0.fileName = "emptyBackingString"
sata0:0.present = "TRUE"
guestOS = "centos7-64"
toolScripts.afterPowerOn = "TRUE"
toolScripts.afterResume = "TRUE"
toolScripts.beforeSuspend = "TRUE"
toolScripts.beforePowerOff = "TRUE"
tools.syncTime = "FALSE"
uuid.bios = "56 4d 89 c6 9b 05 bd 86-51 23 ce 62 dc 25 30 af"
uuid.location = "56 4d fc 7d 7d 14 fe e3-ff 96 34 d2 7a 46 1a 5a"
vc.uuid = "52 6c 43 70 5e 5d 80 0b-bf cb fd 42 72 c4 3b 3d"
sched.cpu.min = "0"
sched.cpu.shares = "normal"
sched.mem.min = "2048"
sched.mem.minSize = "2048"
sched.mem.shares = "normal"
ethernet0.address = "00:50:56:2D:A8:3C"
sata0:0.clientDevice = "TRUE"
sched.mem.pin = "TRUE"
vmci0.id = "-601542481"
cleanShutdown = "FALSE"
numvcpus = "2"
sata0:0.startConnected = "FALSE"
pciPassthru0.id = "00000:008:08.0"
pciPassthru0.deviceId = "0x8006"
pciPassthru0.vendorId = "0xd161"
pciPassthru0.systemId = "63ef8902-ed0a-ed5a-8124-305a3a7943c8"
pciPassthru0.present = "TRUE"
tools.guest.desktop.autolock = "FALSE"
nvram = "FreePBX.nvram"
svga.present = "TRUE"
pciBridge0.present = "TRUE"
pciBridge4.present = "TRUE"
pciBridge4.functions = "8"
pciBridge5.present = "TRUE"
pciBridge5.functions = "8"
pciBridge6.present = "TRUE"
pciBridge6.functions = "8"
pciBridge7.present = "TRUE"
pciBridge7.functions = "8"
hpet0.present = "TRUE"
RemoteDisplay.maxConnections = "-1"
sched.cpu.latencySensitivity = "normal"
svga.autodetect = "TRUE"
numa.autosize.cookie = "20022"
numa.autosize.vcpu.maxPerVirtualNode = "2"
sched.swap.derivedName = "/vmfs/volumes/653ee7e0-976ec211/FreePBX/FreePBX-4258ed17.vswp"
scsi0.pciSlotNumber = "160"
usb.pciSlotNumber = "32"
ethernet0.pciSlotNumber = "224"
ehci.pciSlotNumber = "33"
vmci0.pciSlotNumber = "34"
sata0.pciSlotNumber = "35"
scsi0.sasWWID = "50 05 05 66 9b 05 bd 80"
vmotion.checkpointFBSize = "4194304"
vmotion.checkpointSVGAPrimarySize = "16777216"
vmotion.svga.mobMaxSize = "16777216"
vmotion.svga.graphicsMemoryKB = "16384"
monitor.phys_bits_used = "45"
softPowerOff = "FALSE"
usb:1.speed = "2"
usb:1.present = "TRUE"
usb:1.deviceType = "hub"
usb:1.port = "1"
usb:1.parent = "-1"
svga.guestBackedPrimaryAware = "TRUE"
tools.remindInstall = "FALSE"
cpuid.coresPerSocket = "2"
vmxstats.filename = "FreePBX.scoreboard"
migrate.hostLog = "./FreePBX-c126ceee.hlog"
pciPassthru0.pciSlotNumber = "192"
scsi0:0.redo = ""
svga.vramSize = "16777216"
usb:0.present = "TRUE"
usb:0.deviceType = "hid"
usb:0.port = "0"
usb:0.parent = "-1"
Es ist eine asterisk Card AEX410 2 FXO+2 FXS,Issabel FreePBX Dahdi FXS Card FXO Card tdm410p. Host ist eine ASUS C612 Z10PA-U8 mit Xeon E5-2697A v4. FreePBX liegt auf einem NFS Storage.
Passtrough am Host funktioniert aber soweit, dem Filer ist ein PERC 310i durchgereicht, der läuft.
Weiss da Einer, wieso das plötzlich nicht mehr geht mit meiner Telefonkarte?
Gruss und danke
Re: PSOD bei Passtrough
Beitragvon Dayworker » 05.06.2023, 19:58
Jumpstart plugin restore-nfs-volumes activation failed
Jumpstart plugin restore-networking activation failed
Kann es sein, daß die PBX-Karte mit auf derselben PCIe-Lane wie Netzwerk und AHCI-Controller arbeitet?
Beitragvon MarroniJohny » 05.06.2023, 20:58
Keine Ahnung ehrlich gesagt. Denke aber eher nicht. Ist ja auch gelaufen bislang.Ich glaube seit dem Update U1 geht es nicht mehr. Die Karte steckt im untersten Slot.
Und was meinst Du mit dem Codefenster da?
Beitragvon Martin » 05.06.2023, 22:04
Warum bist du mit solch einer Hardwarekombination überhaupt auf vSphere 8 gegangen?
Beitragvon Dayworker » 06.06.2023, 00:34
@Martin
Berechtigte Frage. Meine Vermutung wäre, daß man dann wieder eine richtig aktuelle ESXi-Version hat und erstmal wieder für mehrere Jahre Ruhe hat.
@MarroniJohny
Beide Meldungen tauchen weiter unten in deinem PSOD auf. Entweder weil der ESXi sich weggehangen hat oder sich den Ast auf dem er sitzt, durch das Passthrough selbst abgesägt hat.
Beitragvon MarroniJohny » 07.06.2023, 16:29
...oder sich den Ast auf dem er sitzt, durch das Passthrough selbst abgesägt hat.
Hmm. Damit könntest Du noch recht haben. Aber ist das korrekte durchreichen nicht ausschliesslich von der Hardware abhängig? Spielt da das OS auch mit rein? Weil es ist ja gelaufen bis vor kurzem.
Und ist beim ESXi ein Downgrade möglich? Ich meinte, mit 8.0-20513097 ist es noch gelaufen. Auch mit 7.0 U3 war alles gut. Clean Install auf eine alte Version habe ich momentan noch nicht so Bock. Da warte ich lieber zu, bis dann hoffentlich eine gefixte Version kommt.
Ich hatte es in einem anderen Fred schon erwähnt. Seit 8.0 U1 ist der Host auch nicht mehr aus anderen vLANs erreichbar. Das stört mich auch.
Beitragvon ~thc » 07.06.2023, 18:22
Es gibt beim PCI-Passthrough drei Komponenten, die genau passen müssen: Mainboard, BIOS/Firmware und OS. Wenn du auch nur eines veränderst, kann es weiter funktionieren - muss aber nicht.
Du hast zudem eine von den Vorgängerversionen übernommene ESXi-Konfiguration - auch die kann natürlich mit von der Partie sein (auch in Richtung VLAN)...
Beitragvon MarroniJohny » 10.06.2023, 01:52
So, hatte die Schnauze voll, und bin auf ESXi-7.0U3g-20328353 zurück gegangen. FreePBX läuft wieder mit meiner Telefonkarte, der vmkernel aus dem fremdem vLAN ist wieder erreichbar, der USB Dongle in einer anderen VM muss nicht jedes Mal neu hinzugefügt werden, und Johny ist glücklich.
War wieder einmal riesen Gebastel bis das alles lief. Von 8.0 bin ich mal geheilt für vorerst.
Danke an alle!
Zurück zu „vSphere 8“
