ESXi3.5 im VMserver1.0.10
Beitragvon Dayworker » 09.09.2012, 12:49
Hier die VMX:
bios.bootdelay = "5000"
config.version = "8"
virtualHW.version = "4"
displayName = "esxi35"
guestOS = "other"
### 2 CPUs (eine genügt auch):
numvcpus = "2"
### RAM entsprechend Host-Ausstattung anpassen:
memsize = "1024"
###Intel:
monitor_control.vt32 = "TRUE"
###AMD:
monitor_control.enable_svm = "TRUE"
###CPU-unabhängig immer notwendig:
monitor_control.restrict_backdoor = "TRUE"
###Tuning:
isolation.tools.hgfs.disable = "TRUE"
sched.mem.pshare.enable = "FALSE"
mainmem.useNamedFile = "FALSE"
MemTrimRate=0
###LSIlogic-Adapter:
scsi0.present = "TRUE"
scsi0.virtualDev = "lsilogic"
scsi0.pciSlotNumber = "16"
###Systemplatte des ESX Servers (nur für System gänge auch IDE, für VMFS nicht):
scsi0:0.present = "TRUE"
scsi0:0.fileName = "ESXi35_system.vmdk"
scsi0:0.redo = ""
###ISO-Image der ESX Installation:
ide1:0.present = "TRUE"
ide1:0.fileName = "VMware-VMvisor-InstallerCD-3.5.0_Update_3-123629.i386.iso"
### Ethernet Intel 1000
### Netzwerke VMnetX eventuell anpassen
ethernet0.present = "TRUE"
ethernet0.connectionType = "custom"
ethernet0.vnet = "VMnet0"
ethernet0.generatedAddress = "00:0c:29:30:39:fe"
ethernet1.present = "FALSE"
ethernet1.startConnected = "FALSE"
ethernet1.virtualDev = "e1000"
ethernet1.connectionType = "custom"
ethernet1.vnet = "VMnet2"
ethernet1.pciSlotNumber = "34"
ethernet1.addressType = "generated"
ethernet1.generatedAddress = "00:0c:29:30:39:08"
ethernet1.generatedAddressOffset = "10"
ethernet2.present = "FALSE"
ethernet2.startConnected = "TRUE"
ethernet2.virtualDev = "e1000"
ethernet2.connectionType = "custom"
ethernet2.vnet = "VMnet8"
ethernet2.pciSlotNumber = "35"
ethernet2.addressType = "generated"
ethernet2.generatedAddress = "00:0c:29:30:39:12"
ethernet2.generatedAddressOffset = "20"
ethernet3.present = "FALSE"
ethernet3.startConnected = "TRUE"
ethernet3.virtualDev = "e1000"
ethernet3.connectionType = "custom"
ethernet3.vnet = "VMnet8"
ethernet3.pciSlotNumber = "36"
ethernet3.addressType = "generated"
ethernet3.generatedAddress = "00:0c:29:30:39:1c"
ethernet3.generatedAddressOffset = "30"
###sonstiges:
floppy0.autodetect = "TRUE"
floppy0.fileName = "vmscsi-1.2.0.4.flp"
usb.present = "FALSE"
ehci.present = "FALSE"
ehci.pciSlotNumber = "33"
sound.present = "FALSE"
sound.fileName = "-1"
sound.autodetect = "TRUE"
svga.autodetect = "TRUE"
pciBridge0.present = "TRUE"
mks.keyboardFilter = "allow"
nvram = "ESXi35.nvram"
tools.remindInstall = "FALSE"
uuid.location = "56 4d 0a 36 f5 04 6d 8e-e9 9f 52 a4 00 86 76 47"
uuid.bios = "56 4d 24 5e bf 72 d1 68-29 55 3f 52 e2 30 39 fe"
floppy0.fileType = "file"
autostop = "softpoweroff"
workingDir = "."
priority.grabbed = "normal"
priority.ungrabbed = "normal"
Beitragvon continuum » 09.09.2012, 16:26
guestOS = "vmkernel"
würde auch funktionieren - es ist leider nirgendswo dokumentiert wo der Unterschied genau liegt ...
Beitragvon Dayworker » 09.09.2012, 16:35
Ich bin ja schon glücklich, daß es überhaupt läuft. Fraglich ist auch, ob der VMserver1 den Gast-Typ "vmkernel" überhaupt kennt.
Nested VMs unter ESXi3 sind jedenfalls leider auf Intel-CPUs entweder nur ab Nehalem oder überhaupt nicht bzw nur auf AMD-CPUs mit AMD-V möglich. Entscheidend scheint dabei zu sein, daß die MMU in HW-VT ausgeführt werden kann.
So jedenfalls verstehe ich den Thread Running ESX inside ESX (3.5) im VMTN.
