Bekomme Datatstores nicht entfernt
Re: Bekomme Datatstores nicht entfernt
Beitragvon Neopolis » 04.06.2020, 13:22
Lieben Dank für eure Infos
Ich mach das alles mal und erstatte Bericht
Beitragvon Neopolis » 04.06.2020, 13:25
Erstmal die ISO Frage
[root@ESX01:~] cat /vmfs/volumes/*/*/*.vmx | grep -i iso
cdrom.showIsoLockWarning = "FALSE"
[root@ESX01:~]
Beitragvon Neopolis » 04.06.2020, 13:26
Scratch Partition:
[root@ESX01:~] vim-cmd hostsvc/advopt/view ScratchConfig.ConfiguredScratchLocation
(vim.option.OptionValue) [
   (vim.option.OptionValue) {
      key = "ScratchConfig.ConfiguredScratchLocation",
      value = "/vmfs/volumes/5ecebdea-0d1f2d9e-be92-002655d94b41/.locker"
[root@ESX01:~]
Dann der Befehl. Dabei habe ich aber bestimmt was falsch gemacht:
[root@ESX01:~] ls -lh /vmfs/devices/disks/ (ls -lh /dev/disks/
-sh: syntax error: unexpected "("
[root@ESX01:~]
Dann der Befehl:
[root@ESX01:~] fdisk -l
*** The fdisk command is deprecated: fdisk does not handle GPT partitions.  Please use partedUtil
fdisk: device has more than 2^32 sectors, can't use all of them
Found valid GPT with protective MBR; using GPT
Disk /dev/disks/naa.600605b003180f202661753f130ee589: 4294967295 sectors, 4095M
Logical sector size: 512
Disk identifier (GUID): aafa2431-87fa-4d3f-b8b9-4dbb9d1e7472
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 23437498334
Number  Start (sector)    End (sector)  Size       Code  Name
   1            2048     23437496320       10.9T   0700
Disk /dev/disks/naa.2020030102060804: 30535680 sectors, 2622M
Disk identifier (GUID): a56c3693-e79d-414d-9cfd-fac726b32828
First usable sector is 34, last usable sector is 30535646
   1              64            8191       4064K   0700
   5            8224          520191        249M   0700
   6          520224         1032191        249M   0700
   7         1032224         1257471        109M   0700
   8         1257504         1843199        285M   0700
   9         1843200         7086079       2560M   0700
Disk /dev/disks/naa.600605b00758f1102661774131ac425d: 4294967295 sectors, 4095M
Disk identifier (GUID): aa68e7a8-1107-42ff-8464-dd465e55b0ed
First usable sector is 34, last usable sector is 46880980958
   1            2048     46880978944       21.8T   0700
Disk /dev/disks/naa.600605b003180f20266175b71a40670a: 697264128 sectors,  493M
Disk identifier (GUID): 77b3c856-05db-482a-bfcb-9e725b1a9efb
First usable sector is 34, last usable sector is 697264094
   1            2048       697262080        332G   0700
[root@ESX01:~]
Beitragvon JustMe » 04.06.2020, 13:42
Nein, Du hast da nichts falsch gemacht.
ICH habe in der Klammer verwirrenderweise einen alternativen Kommandoaufruf angegeben, also muss Deine Eingabe lauten
ODER ALTERNATIV
ls -lh /dev/disks/
Denn /vmfs/devices ist lediglich ein Link auf /dev.
Ansonsten sieht die Tabelle auf /dev/disks/naa.2020030102060804 fuer mich erst einmal gut aus, und ich hoffe (und vermute), dass die Ausgabe EINES der beiden obigen Befehle auf 5ecebdea-0d1f2d9e-be92-002655d94b41 verweist, denn in einem frueheren Post hattest Du schon hier hinein kopiert:
/vmfs/volumes/5ecebdea-0d1f2d9e-be92-002655d94b41  RAID5 22TB (1)  5ecebdea-0d1f2d9e-be92-002655d94b41     true  VMFS-6  24002961604608  22203662860288
und damit zeigt die Scratchconfig auf den 22TB Datastore.
Aber was ist mit der Frage nach der Anzahl der verwendeten Hosts?
Beitragvon Neopolis » 04.06.2020, 17:10
Danke für die ausführliche Info :-) Da lernt man was dabei. Danke!
Hier nun die Ausgaben:
total 71034548130
-rw-------    1 root     root       14.6G Jun  4 15:09 naa.2020030102060804
-rw-------    1 root     root        4.0M Jun  4 15:09 naa.2020030102060804:1
-rw-------    1 root     root      250.0M Jun  4 15:09 naa.2020030102060804:5
-rw-------    1 root     root      250.0M Jun  4 15:09 naa.2020030102060804:6
-rw-------    1 root     root      110.0M Jun  4 15:09 naa.2020030102060804:7
-rw-------    1 root     root      286.0M Jun  4 15:09 naa.2020030102060804:8
-rw-------    1 root     root        2.5G Jun  4 15:09 naa.2020030102060804:9
-rw-------    1 root     root       10.9T Jun  4 15:09 naa.600605b003180f202661753f130ee589
-rw-------    1 root     root       10.9T Jun  4 15:09 naa.600605b003180f202661753f130ee589:1
-rw-------    1 root     root      332.5G Jun  4 15:09 naa.600605b003180f20266175b71a40670a
-rw-------    1 root     root      332.5G Jun  4 15:09 naa.600605b003180f20266175b71a40670a:1
-rw-------    1 root     root       21.8T Jun  4 15:09 naa.600605b00758f1102661774131ac425d
-rw-------    1 root     root       21.8T Jun  4 15:09 naa.600605b00758f1102661774131ac425d:1
lrwxrwxrwx    1 root     root          20 Jun  4 15:09 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520 -> naa.2020030102060804
lrwxrwxrwx    1 root     root          22 Jun  4 15:09 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:1 -> naa.2020030102060804:1
lrwxrwxrwx    1 root     root          22 Jun  4 15:09 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:5 -> naa.2020030102060804:5
lrwxrwxrwx    1 root     root          22 Jun  4 15:09 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:6 -> naa.2020030102060804:6
lrwxrwxrwx    1 root     root          22 Jun  4 15:09 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:7 -> naa.2020030102060804:7
lrwxrwxrwx    1 root     root          22 Jun  4 15:09 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:8 -> naa.2020030102060804:8
lrwxrwxrwx    1 root     root          22 Jun  4 15:09 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:9 -> naa.2020030102060804:9
lrwxrwxrwx    1 root     root          36 Jun  4 15:09 vml.0200000000600605b003180f202661753f130ee589536572766552 -> naa.600605b003180f202661753f130ee589
lrwxrwxrwx    1 root     root          38 Jun  4 15:09 vml.0200000000600605b003180f202661753f130ee589536572766552:1 -> naa.600605b003180f202661753f130ee589:1
lrwxrwxrwx    1 root     root          36 Jun  4 15:09 vml.0200000000600605b003180f20266175b71a40670a536572766552 -> naa.600605b003180f20266175b71a40670a
lrwxrwxrwx    1 root     root          38 Jun  4 15:09 vml.0200000000600605b003180f20266175b71a40670a536572766552:1 -> naa.600605b003180f20266175b71a40670a:1
lrwxrwxrwx    1 root     root          36 Jun  4 15:09 vml.0200000000600605b00758f1102661774131ac425d4d5239323630 -> naa.600605b00758f1102661774131ac425d
lrwxrwxrwx    1 root     root          38 Jun  4 15:09 vml.0200000000600605b00758f1102661774131ac425d4d5239323630:1 -> naa.600605b00758f1102661774131ac425d:1
[root@ESX01:~]
und
[root@ESX01:~] ls -lh /dev/disks/
total 71034548130
-rw-------    1 root     root       14.6G Jun  4 15:10 naa.2020030102060804
-rw-------    1 root     root        4.0M Jun  4 15:10 naa.2020030102060804:1
-rw-------    1 root     root      250.0M Jun  4 15:10 naa.2020030102060804:5
-rw-------    1 root     root      250.0M Jun  4 15:10 naa.2020030102060804:6
-rw-------    1 root     root      110.0M Jun  4 15:10 naa.2020030102060804:7
-rw-------    1 root     root      286.0M Jun  4 15:10 naa.2020030102060804:8
-rw-------    1 root     root        2.5G Jun  4 15:10 naa.2020030102060804:9
-rw-------    1 root     root       10.9T Jun  4 15:10 naa.600605b003180f202661753f130ee589
-rw-------    1 root     root       10.9T Jun  4 15:10 naa.600605b003180f202661753f130ee589:1
-rw-------    1 root     root      332.5G Jun  4 15:10 naa.600605b003180f20266175b71a40670a
-rw-------    1 root     root      332.5G Jun  4 15:10 naa.600605b003180f20266175b71a40670a:1
-rw-------    1 root     root       21.8T Jun  4 15:10 naa.600605b00758f1102661774131ac425d
-rw-------    1 root     root       21.8T Jun  4 15:10 naa.600605b00758f1102661774131ac425d:1
lrwxrwxrwx    1 root     root          20 Jun  4 15:10 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520 -> naa.2020030102060804
lrwxrwxrwx    1 root     root          22 Jun  4 15:10 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:1 -> naa.2020030102060804:1
lrwxrwxrwx    1 root     root          22 Jun  4 15:10 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:5 -> naa.2020030102060804:5
lrwxrwxrwx    1 root     root          22 Jun  4 15:10 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:6 -> naa.2020030102060804:6
lrwxrwxrwx    1 root     root          22 Jun  4 15:10 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:7 -> naa.2020030102060804:7
lrwxrwxrwx    1 root     root          22 Jun  4 15:10 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:8 -> naa.2020030102060804:8
lrwxrwxrwx    1 root     root          22 Jun  4 15:10 vml.0100000000434359594d4d444448486d6d535330585149365553544f524520:9 -> naa.2020030102060804:9
lrwxrwxrwx    1 root     root          36 Jun  4 15:10 vml.0200000000600605b003180f202661753f130ee589536572766552 -> naa.600605b003180f202661753f130ee589
lrwxrwxrwx    1 root     root          38 Jun  4 15:10 vml.0200000000600605b003180f202661753f130ee589536572766552:1 -> naa.600605b003180f202661753f130ee589:1
lrwxrwxrwx    1 root     root          36 Jun  4 15:10 vml.0200000000600605b003180f20266175b71a40670a536572766552 -> naa.600605b003180f20266175b71a40670a
lrwxrwxrwx    1 root     root          38 Jun  4 15:10 vml.0200000000600605b003180f20266175b71a40670a536572766552:1 -> naa.600605b003180f20266175b71a40670a:1
lrwxrwxrwx    1 root     root          36 Jun  4 15:10 vml.0200000000600605b00758f1102661774131ac425d4d5239323630 -> naa.600605b00758f1102661774131ac425d
lrwxrwxrwx    1 root     root          38 Jun  4 15:10 vml.0200000000600605b00758f1102661774131ac425d4d5239323630:1 -> naa.600605b00758f1102661774131ac425d:1
[root@ESX01:~]
Beitragvon JustMe » 04.06.2020, 17:27
Wie erwaehnt: EINE Ausgabe haette gereicht, denn die sind beide identisch. Und sie passen zur Ausgabe von fdisk. (Die UUID taucht hier doch nicht auf, weil es ja eine DS-UUID und nicht vom Geraet ist. Mein naechster Fehler, sorry...)
Aber die Frage nach der Anzahl Deiner in Betrieb befindlichen HP-Hosts hast Du noch immer nicht beantworten wollen :lol:
Ich bin mir einigermassen sicher, dass es nur einer ist, auch wenn der ESX01 heisst.
Sonst haette der iso-Suchbefehl bei mindestens einer auf einem anderen Host ausgefuehrten VM des Shared Storage eine "busy"-Meldung ausgeben muessen.
Uebrigens saehe die Ausgabe mit
cat /vmfs/volumes/*/*/*.vmx | egrep -i "vmxf|iso"
etwas besser aus, denn dann bekommt man auch die VM-Namen mitgeliefert.
Vielleicht hat jemand anderes noch eine Idee; ich jedenfalls komme ohne die Angabe der Hostanzahl (und ob das vCenter vielleicht noch mehr Hosts verwaltet, ob die gerade disconnected oder sonstwas sind, etc.pp.) nicht weiter. Ich verstehe auch nicht, warum da so ein Geheimnis drum gemacht wird...
Beitragvon Neopolis » 04.06.2020, 18:50
Huch. Entschuldige bitte.
Es handelt sich um einen Host mit VMware 6.7 und einem vCenter 6
Um es skalierbar zu machen und vielleicht noch einen zweiten oder gar einen dritten hinzufügen zu können habe ich mal mit -01 angefangen.
Beitragvon Neopolis » 04.06.2020, 18:53
Die Ausgabe finde ich merkwürdig.
Da fehlen VMs. Das sind scheinbar nur die die gerade eingeschaltet sind
[root@ESX01:~] cat /vmfs/volumes/*/*/*.vmx | egrep -i "vmxf|iso"
extendedConfigFile = "vpMediaserver Neu.vmxf"
extendedConfigFile = "vpBanking.vmxf"
extendedConfigFile = "vsDCw2k8R2-01.vmxf"
extendedConfigFile = "vsExchange.vmxf"
extendedConfigFile = "vsMAS-DC-01-2019.vmxf"
extendedConfigFile = "vsMAS-SRV-Verwaltung-2016.vmxf"
extendedConfigFile = "vsSharePoint.vmxf"
[root@ESX01:~]
Beitragvon Dayworker » 04.06.2020, 21:38
Echt jetzt?
Das vCenter muß versionstechnisch mindestens gleich oder höher der genutzten ESXi-Version sein. Mit einem älteren vCenter kannst du keinen neuen ESXi verwalten.
Beitragvon JustMe » 04.06.2020, 22:00
Hm, nein, nicht ganz. Die .vmxf enthaelt zusaetzliche Konfigurationsinformationen einer VM, aber nicht jeder Typ VM hat so eine Datei.
Ich habe es nur als Vehikel verwendet, um eine Zeile mit dem Namen der VM auszugeben. Stattdessen (also statt "vmxf") koenntest Du auf ESXi fuer aber auch wieder nur zumindest fast alle VMs auch "scsi0:0.filename" beim egrep-Pattern verwenden. Dabei gingen Dir aber u.U. VMs mit nur IDE- und/oder SATA-vmdks durch die Lappen. Wenn man allerdings alles zusammen in das Pattern packt, wird die Ausgabe nur unuebersichtlich. Leute mit etwas mehr Knoffhoff von der bash-aehnlichen busybox-Shell des ESXi koennten wohl auch einen smarteren Oneliner zimmern, aber fuer mich hat's bisher immer so ausgereicht.
Wo genau laeuft eigentlich Dein vCenter Server? Als Appliance, oder auf einer der Windows-VMs?
Und wie sieht die Konfiguration innerhalb des vCenters aus? Hast Du den Host direkt im Datacenter aufgenommen, oder bereits einen 1-Host-Cluster eingerichtet?
Was greift denn bereits so alles auf das vCenter zu (z.B. Backup-Programme, ...)?
Als pragmatische Loesung schwebt mir vor, einfach den Host aus dem vCenter zu werfen (erst trennen, dann loeschen; dabei laufen die VMs weiter), das Datacenter zu loeschen, und neu mit einem solchen anzufangen. Das sollte auch die jetzt veralteten Kenntnisse des bei der HW-Veraenderung ja ausgeschalteten vCenters verwerfen. Die ganze erwaehnte Netzwerkkonfiguration (und auch so ziemlich alles andere wie z.B. VM-Einstellungen) duerfte sich ja in der Konfig und den Datastores des Hosts ESX01 befinden. Oder hast Du etwa mit dem einen einsamen Host eine Enterprise-Plus-Lizenz in Verwendung, und einen Distributed vSwitch eingerichtet?
PS: Ich nehme mal an, dass "vCenter 6" NICHT "vCenter 6.0" heisst, sonst waere der Host ja auch VOR der HW-Aenderung nicht drin verwaltet worden...
Beitragvon Neopolis » 05.06.2020, 16:27
Die vCenter Version ist aktuell nur nicht 7 und läuft als Appliance auf dem ESX01
Das mit dem Host entfernen kann ich gern probieren.
Distributed vSwitch ist nicht eingerichtet.
Ja es war ein einsamer Host mit einer Enterprise Plus Lizenz. Ich habe gestern och einen ESX02 hinzugefügt. Dieser ist aber schon recht betagt und sollte nur im Fall der allergrößten Not die eine oder andere VM übernehmen. Dazu habe ich noch eine Synology an beide Hosts angebunden.
Ich könnte somit den ESX neu installieren, wenn es sein sollte.
Was denkt ihr? Macht es Sinn?
Es gibt Veeam das auf das vCenter zugreift und Datensicherungen durchführt. Das kann aber auch neu konfiguriert werden
Beitragvon Neopolis » 05.06.2020, 16:55
Update:
Host ESX02 aus dem vCenter getrennt und aus Bestandsliste entfernt. Keine Probleme
ESX02 wieder hinzugefügt. Alles palletti
ESX01 getrennt und aus Bestandsliste entfernt. Keine Probleme
ESX01 wieder hinzugefügt. Alles palletti.
Nur noch die Datastores werden angezeigt die auch tatsächlich da sind.
Coole Sache. Danke euch!!!
Schönes Wochenende.
Beitragvon JustMe » 05.06.2020, 17:05
Na, das ist doch erfreulich so vor dem Wochenende. ;)
Wenn Du jetzt mehrere Hosts betreibst, solltest Du, falls noch nicht bedacht, darauf achten, dass die nicht alle in dasselbe Scratchverzeichnis auf dem 22TB Datastore schreiben. Das erzeugt nur Kuddelmuddel, und VMware haette auch gerne 1 Verzeichnis je Host. Scratchconfig musst Du ja koennen, sonst waere das von ESX01 nicht schon auf dem 22TB-DS...
Zurück zu „vSphere 6.7“
