was ist dieser "parallel"-Snapshot?
Beitragvon JustMe » 03.09.2015, 16:57
Ich bin erst einmal raus; die Drop(Out)Box verlangt 'ne Registrierung von mir.
Beitragvon Dayworker » 04.09.2015, 13:38
Wenn das DB-Reg-Fenster aufploppt, kannst du über oben rechts das Kreuz das Anmelde-Fenster wieder schliessen. Ich war auch darüber gestolpert...
Beitragvon Dayworker » 06.09.2015, 15:13
Zeile 859ff
2015-09-01T18:40:01.445Z| Worker#1| I120: ToolsVersion: Status is supported old because this is status of monolithic version, and vcbprovider_2003 and 65 more components are missing from the guest.
2015-09-01T18:40:01.445Z| Worker#1| I120: ToolsVersionGetStatusWorkerThread: Tools status 2 derived from environment
2015-09-01T18:40:01.449Z| Worker#1| I120: GetHostManifests: Extracting the manifest file.
Teile 2259ff
2015-09-01T18:42:54.263Z| vmx| I120: TOOLS INSTALL entering BEGINNING state.
2015-09-01T18:42:54.279Z| vmx| I120: TOOLS INSTALL Attempting auto-upgrade.
2015-09-01T18:42:54.280Z| vmx| I120: TOOLS installed legacy version 9349, available legacy version 9354
2015-09-01T18:42:54.280Z| vmx| I120: TOOLS manifest update status is 2
2015-09-01T18:42:54.280Z| vmx| I120: TOOLS can be autoupgraded.
2015-09-01T18:42:54.280Z| vmx| I120: TOOLS INSTALL Launching auto-upgrader with args "".
2015-09-01T18:42:54.280Z| vmx| I120: TOOLS INSTALL autoupgrading old tools.
2015-09-01T18:42:54.284Z| vmx| I120: TOOLS INSTALL Copying upgrader files from /usr/lib/vmware/isoimages/windows.iso into guest at C:\Windows\TEMP\vmware-SYSTEM\
2015-09-01T18:42:54.284Z| vcpu-1| I120: HGFileCopyCreateSessionCB: Successfully created the session.
2015-09-01T18:42:54.330Z| vcpu-1| I120: TOOLS INSTALL finished copying upgrader binary into guest. Starting Upgrader in guest.
2015-09-01T18:42:54.330Z| vcpu-1| I120: TOOLS INSTALL entering INSERTED state.
2015-09-01T18:42:54.330Z| vcpu-1| I120: TOOLS INSTALL Sending "upgrader.create 1"
2015-09-01T18:42:54.385Z| vcpu-0| I120: TOOLS INSTALL completed Foundry upgrade.
2015-09-01T18:42:54.474Z| vcpu-0| I120: TOOLS INSTALL entering COPYING state.
2015-09-01T18:42:54.474Z| vcpu-0| I120: TOOLS INSTALL image verified.
VMware-Tools erfolgreich aktualisiert.
Zur Frage was dieser Parallel-Snapshot ist, würde ich sagen, daß das mit der Arbeitsweise von CBT zusammenhängt. Zu jedem Snapshot scheint CBT noch einen weiteren internen zu erstellen, um über den VM-Kernel die zwischenzeitlich veränderten Blöcke zu erfassen. Für genaueres fehlt mir das Hintergrundwissen, wie CBT genau realisiert wurde.
Beitragvon Odi » 07.09.2015, 10:47
Das seltsame dabei ist das das nur bei einigen Maschinen passiert.
Von ungefähr 50 Vm's ist es mir bei ca. 4 Maschinen aufgefallen.
edit: hab gerade einen Snapshot OHNE der option "GastDateisystem stillegen" gemacht und da siehts nachher normal aus!
Beitragvon Dayworker » 07.09.2015, 18:25
Lies dir mal bitte den KB-Eintrag Understanding virtual machine snapshots in VMware ESXi and ESX (1015180) durch. Deine Option "GastDateisystem stillegen" ist dort unter "Quiesce" zu finden....
Mein Rat wäre als erstes, auf die englische Benutzeroberfläche umzuschalten, da man mit der 1:1-Übersetzung von VMware bekanntermaßen nicht sehr weit kommt und Suchmaschinen damit auch nichts finden können.
