VDR - Wiederherstellen eines virtuellen Servers
Beitragvon Zaphod.Beeblebrox » 26.01.2011, 11:34
Folgende Dateien sind wiederhergestellt worden:
SMGE134.nvram
SMGE134.vmdk
SMGE134.vmsd
SMGE134.vmx
SMGE134.vmxf
SMGE134-32fc0924.vswp
SMGE134-ctk.vmdk
SMGE134-flat.vmdk
vmware.log
Beitragvon Zaphod.Beeblebrox » 26.01.2011, 12:24
Folgendes wird beim Starten ins vmware.log geschrieben:
Jan 26 12:17:29.249: vmx| DICT guest.commands.sharedPolicyRefCount = 0
Jan 26 12:17:29.259: vmx| Vix: [114651 mainDispatch.c:3248]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1
Jan 26 12:17:29.262: vmx| hostCpuFeatures = 0x444001fc
Jan 26 12:17:29.263: vmx| hostNumPerfCounters = 2
Jan 26 12:17:29.265: vmx| MONITOR MODE: allowed modes : BT HV
Jan 26 12:17:29.265: vmx| MONITOR MODE: user requested modes : BT HV HWMMU
Jan 26 12:17:29.266: vmx| MONITOR MODE: guestOS preferred modes: HWMMU BT HV
Jan 26 12:17:29.267: vmx| MONITOR MODE: filtered list : BT HV
Jan 26 12:17:29.268: vmx| HV Settings: virtual exec = 'dynamic'; virtual mmu = 'software'
Jan 26 12:17:29.416: vmx| VMMon_ConfigMemSched: vmmon.numVCPUs=1
Jan 26 12:17:29.418: vmx| CreateVM: Swap: generating normal swap file name.
Jan 26 12:17:29.419: vmx| Swap file path: '/vmfs/volumes/4d0475a3-922dfd1c-09ef-00199901675c/SMGE134/SMGE134-32fc0924.vswp'
Jan 26 12:17:29.674: vmx| Using swap file '/vmfs/volumes/4d0475a3-922dfd1c-09ef-00199901675c/SMGE134/SMGE134-32fc0924.vswp'
Jan 26 12:17:29.675: vmx| VMXVmdb_LoadRawConfig: Loading raw config
Jan 26 12:17:29.732: vmx| LogBackupByRenumber: failed to read the directory '/vmfs/volumes/4d0475a3-922dfd1c-09ef-00199901675c/SMGE134/stats'.
Jan 26 12:17:29.734: vmx| LogBackupByRenumber: failed to read the directory '/vmfs/volumes/4d0475a3-922dfd1c-09ef-00199901675c/SMGE134/stats'.
Jan 26 12:17:29.741: vmx| vmm32-modules: [vmm.vmm32 .data:0x2b000-0xe44 .sdata:0x2c000-0x4e4 .statvars:0x2d000-0x3a8 .peer:0x2e000-0x261c0 .shared:0x56000-0x1a600 .bss:0x71000-0x5dc8 .rodata:0x78000-0xbee0 .text:0x85000-0x6189d .kstatvars:0x3000-0x0, mmu-pae.vmm32 .rodata:0x83ee0-0x44 .data:0x2be44-0xc .peer:0x541c0-0x16c0 .shared:0x70600-0x380 .bss:0x76de0-0x51c .text:0xe68a0-0xa927 .comment:0x40000e10-0x10e .statvars:0x2000-0x0 .kstatvars:0x2000-0x0 .scb:0x40005040-0x180 .shared_meta:0x40004fb0-0x390 .peer_meta:0x40000ea0-0x210, sharedmmu-none.vmm32 .text:0xf11c8-0x37 .comment:0x40000f1e-0x12, pv-none.vmm32 .shared:0x70980-0x180 .bss:0x77300-0x84 .text:0xf1200-0xe2 .comment:0x40000f30-0x48 .shared_meta:0x40005340-0x90, vprobe-none.vmm32 .text:0xf12e4-0x19 .comment:0x40000f78-0x12, hv-vt.vmm32 .rodata:0x83f24-0x4 .data:0x1000-0x0 .peer:0x1000-0x0 .shared:0x1000-0x0 .bss:0x1000-0x0 .text:0xf1300-0x1a1 .comment:0x40000f8a-0x12 .statvars:0x1000-0x0 .kstatvars:0x1000-0x0, gphys-sw.vmm32 .peer:0x55880-0x40 .shared:0x70b00-0x80 .bss:0x2000-0x0 .text:0xf14b0-0x763 .comment:0x40000f9c-0x12 .scb:0x400051c0-0x60 .shared_meta:0x400053d0-0x240 .peer_meta:0x400010b0-0x30, vassert-none.vmm32 .text:0xf1c14-0xf .comment:0x40000fae-0x12, vmsafe-none.vmm32 .text:0xf1c24-0x1b .comment:0x40000fc0-0x12, videio-none.vmm32 .rodata:0x83f28-0xdf .data:0x1000-0x0 .peer:0x1000-0x0 .shared:0x1000-0x0 .bss:0x1000-0x0 .text:0xf1c40-0xaa .comment:0x40000fd2-0x12 .statvars:0x1000-0x0 .kstatvars:0x1000-0x0, <MonSrcFile> .rodata:0x84007-0x3e9]
Jan 26 12:17:29.744: vmx| KHZEstimate 1995000
Jan 26 12:17:29.744: vmx| MHZEstimate 1995
Jan 26 12:17:29.745: vmx| NumVCPUs 1
Jan 26 12:17:29.747: vmx| UUID: location-UUID is 56 4d 93 47 11 f1 78 2c-80 6b b7 20 b1 e9 09 1d
Jan 26 12:17:29.749: vmx| AIOGNRC: numThreads=2 ide=0, scsi=0, passthru=1
Jan 26 12:17:29.750: vmx| WORKER: Creating new group with numThreads=2 (2)
Jan 26 12:17:29.752: vmx| CPU0: PMC: IA32, CORE 2 [c:1 f:1 e:1]
Jan 26 12:17:29.754: vmx| CPU1: PMC: IA32, CORE 2 [c:1 f:1 e:1]
Jan 26 12:17:29.756: vmx| CPU2: PMC: IA32, CORE 2 [c:1 f:1 e:1]
Jan 26 12:17:29.758: vmx| CPU3: PMC: IA32, CORE 2 [c:1 f:1 e:1]
Jan 26 12:17:29.760: vmx| CPU4: PMC: IA32, CORE 2 [c:1 f:1 e:1]
Jan 26 12:17:29.762: vmx| CPU5: PMC: IA32, CORE 2 [c:1 f:1 e:1]
Jan 26 12:17:29.764: vmx| CPU6: PMC: IA32, CORE 2 [c:1 f:1 e:1]
Jan 26 12:17:29.766: vmx| CPU7: PMC: IA32, CORE 2 [c:1 f:1 e:1]
Jan 26 12:17:29.768: vmx| minDEThreshold: 70
Jan 26 12:17:29.808: vmx| Mapped mainmem as pageable
Jan 26 12:17:29.809: vmx| MMCHK: Disabling checks which are not forced, cannot do checks on certain processors.
Jan 26 12:17:29.810: vmx| MStat: Creating Stat vm.uptime
Jan 26 12:17:29.811: vmx| MStat: Creating Stat vm.suspendTime
Jan 26 12:17:29.811: vmx| MStat: Creating Stat vm.powerOnTimeStamp
Jan 26 12:17:29.813: vmx| VMXAIOMGR: Using: simple=Generic unbuf=Generic
Jan 26 12:17:29.831: vmx| VMXVmdb_LoadRawConfig: Loading raw config
Jan 26 12:17:29.839: vmx| DISK: OPEN scsi0:0 '/vmfs/volumes/4d0475a3-922dfd1c-09ef-00199901675c/SMGE134/SMGE134.vmdk' persistent R[]
Jan 26 12:17:29.855: vmx| DISKLIB-VMFS : "/vmfs/volumes/4d0475a3-922dfd1c-09ef-00199901675c/SMGE134/SMGE134-flat.vmdk" : open successful (10) size = 64424509440, hd = 123699911. Type 3
Jan 26 12:17:29.855: vmx| DISKLIB-DSCPTR: Opened [0]: "SMGE134-flat.vmdk" (0xa)
Jan 26 12:17:29.856: vmx| DISKLIB-LINK : Opened '/vmfs/volumes/4d0475a3-922dfd1c-09ef-00199901675c/SMGE134/SMGE134.vmdk' (0xa): vmfs, 125829120 sectors / 60 GB.
Jan 26 12:17:29.860: vmx| DISKLIB-LIB : Resuming change tracking.
Jan 26 12:17:29.865: vmx| DISKLIB-CBT : Initializing ESX kernel change tracking for fid 123699911.
Jan 26 12:17:29.866: vmx| DISKLIB-CBT : Successfuly created cbt node 75f82c7-cbt.
Jan 26 12:17:29.866: vmx| DISKLIB-CBT : Opening cbt node /vmfs/devices/cbt/75f82c7-cbt
Jan 26 12:17:29.867: vmx| DISKLIB-LIB : Opened "/vmfs/volumes/4d0475a3-922dfd1c-09ef-00199901675c/SMGE134/SMGE134.vmdk" (flags 0xa).
Jan 26 12:17:29.869: vmx| DISK: OPEN '/vmfs/volumes/4d0475a3-922dfd1c-09ef-00199901675c/SMGE134/SMGE134.vmdk' Geo (7832/255/63) BIOS Geo (0/0/0)
Jan 26 12:17:29.885: vmx| TimeTracker host to guest rate conversion 5016418336591572 @ 1995000000Hz -> 5016418336591572 @ 1995000000Hz
Jan 26 12:17:29.886: vmx| TimeTracker host to guest rate conversion ((x * 2147483648) >> 31) + 0
Jan 26 12:17:29.904: vmx| MKS not attempting to initialize X.
Jan 26 12:17:29.929: vmx| WORKER: Creating new group with numThreads=1 (3)
Jan 26 12:17:29.929: vmx| MKS: Base polling period is 1000000us
Jan 26 12:17:29.931: vmx| MKS REMOTE Loading VNC Configuration from VM config file
Jan 26 12:17:29.935: vmx| VLANCE: send cluster threshold is 80, size = 2 recalcInterval is 2 ticks
Jan 26 12:17:29.939: vmx| Chipset version: 0x13
Jan 26 12:17:29.991: vmx| DISKUTIL: ide0:0 : capacity=0
Jan 26 12:17:29.992: vmx| DISKUTIL: ide0:0 : geometry=0/0/0
Jan 26 12:17:29.993: vmx| LSI: vIC initialized 50/4/100/0
Jan 26 12:17:29.994: vmx| SCSI0: UNTAGGED commands will be converted to ORDER tags.
Jan 26 12:17:29.996: vmx| Creating virtual dev for scsi0:0
Jan 26 12:17:29.997: vmx| DumpDiskInfo: scsi0:0 createType=11, capacity = 125829120, numLinks = 1, allocationType = 1
Jan 26 12:17:29.999: vmx| VM has zeroedthick disk scsi0:0; FT enable will be disallowed
Jan 26 12:17:30.000: vmx| SCSIDiskESXPopulateVDevDesc: Using FS backend
Jan 26 12:17:30.003: vmx| Msg_Post: Warning
Jan 26 12:17:30.004: vmx| [msg.svgaUI.badLimits] Insufficient video RAM. The maximum resolution of the virtual machine will be limited to 1176x885 at 16 bits per pixel. To use the configured maximum resolution of 2360x1770 at 16 bits per pixel, increase the amount of video RAM allocated to this virtual machine by setting svga.vramSize="16708800" in the virtual machine's configuration file.
Jan 26 12:17:30.005: vmx| ----------------------------------------
Jan 26 12:17:30.033: vmx| SVGA: Truncated max res to VRAM size: 4194304 bytes VRAM, 1176x885 Max Resolution
Jan 26 12:17:30.055: vmx| Ethernet0 MAC Address: 00:50:56:91:7e:91
Jan 26 12:17:30.068: vmx| MStat: Creating Stat vm.heartbeat
Jan 26 12:17:30.069: vmx| TOOLS Generated SessionId 12984704923295954073
Jan 26 12:17:30.070: vmx| VMXVmdbGuest_GetToolsVersion did nothing; tools version has not yet been initialized
Jan 26 12:17:30.071: vmx| DISKUTIL: scsi0:0 : toolsVersion = 0
Jan 26 12:17:30.072: vmx| DISKUTIL: Offline toolsVersion = 0
Jan 26 12:17:30.072: vmx| VMXVmdbGuest_GetToolsVersion did nothing; tools version has not yet been initialized
Jan 26 12:17:30.073: vmx| TOOLS setting legacy tools version to '0', manifest status is 5
Jan 26 12:17:30.074: vmx| VMXVmdb_SetToolsVersionState: status value set to 'noTools'
Jan 26 12:17:30.076: vmx| Msg_Hint: msg.tools.toolsReminder (sent)
Jan 26 12:17:30.076: vmx| Do not forget to install the VMware Tools package inside this virtual machine: wait until your guest operating system finishes booting, then choose VM > Install VMware Tools… and follow the instructions.
Jan 26 12:17:30.076: vmx| ---------------------------------------
Jan 26 12:17:30.102: vmx| TOOLS INSTALL initializing state to IDLE on power on.
Jan 26 12:17:30.125: vmx| PTSC to VMI Wallclock (nsec) 5016418815745344 @ 1995000000Hz -> 1296040650000000000 @ 1000000000Hz
Jan 26 12:17:30.126: vmx| PTSC to VMI Wallclock (nsec) ((x * 2152865812) >> 32) + 1293526154353630432
Jan 26 12:17:30.126: vmx| PTSC to ParaTime RealCycles 0 @ 1995000000Hz -> 0 @ 1995000000Hz
Jan 26 12:17:30.127: vmx| PTSC to ParaTime RealCycles ((x * 1) >> 0) + 0
Jan 26 12:17:30.128: vmx| ParaTime RealCycles to PTSC 0 @ 1995000000Hz -> 0 @ 1995000000Hz
Jan 26 12:17:30.128: vmx| ParaTime RealCycles to PTSC ((x * 1) >> 0) + 0
Jan 26 12:17:30.131: vmx| memoryHotplug: Current size = 4096MB, Minimum size = 4096MB, Maximum size = 4096MB
Jan 26 12:17:30.131: vmx| memoryHotplug: Entry[0]: 00000000000000A0-00000000000A0000
Jan 26 12:17:30.132: vmx| memoryHotplug: Entry[1]: 00000000001000A0-00000000C0000000
Jan 26 12:17:30.133: vmx| memoryHotplug: Entry[2]: 00000001000000A0-0000000140000000
Jan 26 12:17:30.139: vmx| guestCpuFeatures = 0x404001fc
Jan 26 12:17:30.358: vmx| VMXVmdb_LoadRawConfig: Loading raw config
Jan 26 12:17:30.366: vmx| guestCPUID vendor: GenuntelineI
Jan 26 12:17:30.367: vmx| guestCPUID level 00000000, 0: 0x0000000a 0x756e6547 0x6c65746e 0x49656e69
Jan 26 12:17:30.367: vmx| guestCPUID level 00000001, 0: 0x000006f7 0x00010800 0x80002201 0x0febfbff
Jan 26 12:17:30.368: vmx| guestCPUID level 0000000a, 0: 0x07280202 0x00000000 0x00000000 0x00000000
Jan 26 12:17:30.368: vmx| guestCPUID level 40000000, 0: 0x40000010 0x61774d56 0x4d566572 0x65726177
Jan 26 12:17:30.369: vmx| guestCPUID level 40000010, 0: 0x001e70f8 0x000101d0 0x00000000 0x00000000
Jan 26 12:17:30.370: vmx| guestCPUID level 80000000, 0: 0x80000008 0x00000000 0x00000000 0x00000000
Jan 26 12:17:30.370: vmx| guestCPUID level 80000001, 0: 0x00000000 0x00000000 0x00000001 0x20100800
Jan 26 12:17:30.371: vmx| guestCPUID level 80000008, 0: 0x00003028 0x00000000 0x00000000 0x00000000
Jan 26 12:17:30.374: vmx| BusMemSample: initPercent 75 touched 0
Jan 26 12:17:30.376: vmx| Vix: [114651 mainDispatch.c:663]: VMAutomation_PowerOn. Powering on.
Jan 26 12:17:30.380: vmx| VMX_PowerOn: ModuleTable_PowerOn = 1
Jan 26 12:17:30.380: vmx| VMX setting maximum IPC write buffers to 0 packets, 0 bytes
Jan 26 12:17:30.381: vmx| Set thread 1 stack size to 2097152: Success
Jan 26 12:17:30.382: mks| Async MKS thread is alive
Jan 26 12:17:30.383: vmx| Set thread 4 stack size to 1048576: Success
Jan 26 12:17:30.384: vcpu-0| VMMon_Start: vcpu-0: worldID=14652
Jan 26 12:17:30.387: vcpu-0| APIC: version = 0x14, max LVT = 5
Jan 26 12:17:30.393: vcpu-0| APIC: LDR = 0x4000000, DFR = 0xffffffff
Jan 26 12:17:30.399: vcpu-0| guestCpuFeatures = 0x404001fc
Jan 26 12:17:30.400: vcpu-0| LSI:Initialize adapter 0
Jan 26 12:17:30.402: vcpu-0| CPU reset: hard
Jan 26 12:17:30.402: vcpu-0| memoryHotplug: Entry[0]: 00000000000000A0-00000000000A0000
Jan 26 12:17:30.403: vcpu-0| memoryHotplug: Entry[1]: 00000000001000A0-00000000C0000000
Jan 26 12:17:30.404: vcpu-0| memoryHotplug: Entry[2]: 00000001000000A0-0000000140000000
Jan 26 12:17:30.408: vcpu-0| FILE: Bad statfs using /var/lock/LCK..ttyS0 (No such file or directory).
Jan 26 12:17:30.410: vcpu-0| Vix: [114654 mainDispatch.c:3248]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1872, success=1
Jan 26 12:17:30.424: vcpu-0| Vix: [114654 mainDispatch.c:3169]: VMAutomationReportPowerStateChange: Reporting power state change (opcode=0, err=0).
Jan 26 12:17:30.425: vcpu-0| Vix: [114654 mainDispatch.c:3169]: VMAutomationReportPowerStateChange: Reporting power state change (opcode=2, err=0).
Jan 26 12:17:30.425: vcpu-0| Transitioned vmx/execState/val to poweredOn
Jan 26 12:17:30.432: vcpu-0| sz=2906064
Jan 26 12:17:30.482: vmx| VMXVmdb_LoadRawConfig: Loading raw config
Jan 26 12:17:30.553: vcpu-0| vmm32 initialized: Releasebuild-294855. cflags: 0x00000000.00000000.0801a000.00110003
Jan 26 12:17:30.705: vcpu-0| MonitorInitNumaUnmapVMM32
Jan 26 12:17:31.229: vcpu-0| SVGA: Registering MemSpace at 0xd4000000(0x0) and 0xd8000000(0x0)
Jan 26 12:17:31.236: vcpu-0| SVGA: Unregistering MemSpace at 0xd4000000(0xd4000000) and 0xd8000000(0xd8000000)
Jan 26 12:17:31.505: vcpu-0| SVGA: Registering MemSpace at 0xd4000000(0xd4000000) and 0xd8000000(0xd8000000)
Jan 26 12:17:31.515: vcpu-0| SVGA: Unregistering MemSpace at 0xd4000000(0xd4000000) and 0xd8000000(0xd8000000)
Jan 26 12:17:31.517: vcpu-0| SVGA: Registering IOSpace at 0x10d0
Jan 26 12:17:31.517: vcpu-0| SVGA: Registering MemSpace at 0xd4000000(0xd4000000) and 0xd8000000(0xd8000000)
Jan 26 12:17:31.525: vcpu-0| PCIBridge4: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.527: vcpu-0| pciBridge4:1: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.530: vcpu-0| pciBridge4:2: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.532: vcpu-0| pciBridge4:3: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.535: vcpu-0| pciBridge4:4: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.537: vcpu-0| pciBridge4:5: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.539: vcpu-0| pciBridge4:6: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.542: vcpu-0| pciBridge4:7: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.544: vcpu-0| PCIBridge5: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.547: vcpu-0| pciBridge5:1: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.549: vcpu-0| pciBridge5:2: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.551: vcpu-0| pciBridge5:3: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.554: vcpu-0| pciBridge5:4: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.556: vcpu-0| pciBridge5:5: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.558: vcpu-0| pciBridge5:6: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.561: vcpu-0| pciBridge5:7: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.563: vcpu-0| PCIBridge6: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.566: vcpu-0| pciBridge6:1: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.568: vcpu-0| pciBridge6:2: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.570: vcpu-0| pciBridge6:3: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.573: vcpu-0| pciBridge6:4: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.575: vcpu-0| pciBridge6:5: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.577: vcpu-0| pciBridge6:6: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.580: vcpu-0| pciBridge6:7: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.582: vcpu-0| PCIBridge7: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.585: vcpu-0| pciBridge7:1: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.587: vcpu-0| pciBridge7:2: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.589: vcpu-0| pciBridge7:3: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.592: vcpu-0| pciBridge7:4: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.594: vcpu-0| pciBridge7:5: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.596: vcpu-0| pciBridge7:6: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.599: vcpu-0| pciBridge7:7: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.818: vcpu-0| PCIBridge4: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.820: vcpu-0| pciBridge4:1: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.823: vcpu-0| pciBridge4:2: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.825: vcpu-0| pciBridge4:3: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.827: vcpu-0| pciBridge4:4: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.830: vcpu-0| pciBridge4:5: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.832: vcpu-0| pciBridge4:6: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.835: vcpu-0| pciBridge4:7: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.837: vcpu-0| PCIBridge5: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.839: vcpu-0| pciBridge5:1: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.842: vcpu-0| pciBridge5:2: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.844: vcpu-0| pciBridge5:3: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.847: vcpu-0| pciBridge5:4: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.849: vcpu-0| pciBridge5:5: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.851: vcpu-0| pciBridge5:6: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.854: vcpu-0| pciBridge5:7: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.856: vcpu-0| PCIBridge6: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.858: vcpu-0| pciBridge6:1: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.861: vcpu-0| pciBridge6:2: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.863: vcpu-0| pciBridge6:3: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.866: vcpu-0| pciBridge6:4: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.868: vcpu-0| pciBridge6:5: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.870: vcpu-0| pciBridge6:6: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.873: vcpu-0| pciBridge6:7: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.876: vcpu-0| PCIBridge7: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.878: vcpu-0| pciBridge7:1: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.880: vcpu-0| pciBridge7:2: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.883: vcpu-0| pciBridge7:3: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.885: vcpu-0| pciBridge7:4: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.888: vcpu-0| pciBridge7:5: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.890: vcpu-0| pciBridge7:6: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.892: vcpu-0| pciBridge7:7: ISA/VGA decoding enabled (ctrl 0004)
Jan 26 12:17:31.904: vcpu-0| DISKUTIL: scsi0:0 : geometry=7832/255/63
Jan 26 12:17:31.907: vcpu-0| DISKUTIL: scsi0:0 : capacity=125829120
Jan 26 12:17:32.157: vcpu-0| BIOS-UUID is 42 32 a5 9f 7e 5d 99 b5-8a 74 01 a8 80 7f 05 fe
Jan 26 12:17:32.831: mks| MKS: Base polling period is 10000us
Jan 26 12:17:32.832: mks| VGA_Expose ignoring update request due to pending change(s): size palette font.
Jan 26 12:17:33.311: mks| VNCENCODE 2 encoding mode change: (720x400x16depth,16bpp,1440bytes/line)
Jan 26 12:17:33.322: mks| VNCENCODE 2 encoding mode change: (720x400x16depth,16bpp,1440bytes/line)
Jan 26 12:18:06.255: vcpu-0| Msg_Post: Warning
Jan 26 12:18:06.256: vcpu-0| [msg.Backdoor.OsNotFound] No bootable device was detected. A bootable device might be a CD, floppy, hard disk, or network device, as when booting with PXE.
Jan 26 12:18:06.256: vcpu-0| To install an operating system, insert a bootable CD or floppy and restart the virtual machine.----------------------------------------
Beitragvon irix » 26.01.2011, 13:03
Dayworker hat geschrieben:Boote die VM doch mal von einer Live-CD und schau nach, ob überhaupt etwas und was genau drauf ist.
Kannst du bitte mal durchfuehren was Dayworker vorgeschlagen hatte? Bei der Gelegenheit gleich schauen ob die Partition noch als Aktiv gekennzeichnet ist.
Ansonsten.... wenn so gravierende Probleme mit dem "super und tollen" VMware DR hast warum kippst du die nicht bei VMware ab? Nur so sehen die das da Bedarf ist an Verbesserungen :)
Beitragvon Zaphod.Beeblebrox » 26.01.2011, 13:15
irix hat geschrieben:
Dayworker hat geschrieben:Kannst du bitte mal durchfuehren was Dayworker vorgeschlagen hatte? Bei der Gelegenheit gleich schauen ob die Partition noch als Aktiv gekennzeichnet ist.
Hatte ich doch gemacht:
SMGE134.nvram
SMGE134.vmdk
SMGE134.vmsd
SMGE134.vmx
SMGE134.vmxf
SMGE134-ctk.vmdk
SMGE134-flat.vmdk
vmware.log
Ich dachte, dieses Forum kann einem eventuell auch weiterhelfen und das vielleicht schneller als vmware?
Beitragvon irix » 26.01.2011, 13:26
Zaphod.Beeblebrox hat geschrieben:Hatte ich doch gemacht:
Du hast eine Dateiliste gepostet und Groessenangaben. Scheint erstmal komplett zusein aber
1. Keine Daten drauf
2. kein MBR/nicht Aktiv die Partition
Ergo boote ENDLICH von einer LiveCD und mounte die eine Platte und gucke drauf. Hatte die VM mehr als eine vDisk und fehlen evtl. welche?
Zum Schluss... in meinen Augen zeigt das DR Produkt gravierende Maengel bzw. ist nicht tauglich. Die vielen Probleme welche du hier postest und auch andere hatten muessem dem VMware Support mitgeteilt werden.
Es ist nicht so das wir dir nicht helfen wollen.... nur setzen nicht allzuviele das Produkt ein.
Beitragvon PeterDA » 26.01.2011, 13:29
Oh Man,
du sollst die VM mit einem Koppix Booten nicht den ESX!
Sicher können wir dir helfen allerdings bedarf es auch deiner Mithilfe! Und dann ist ist VDR so ein, ich will es mal so ausdrücken spezielles Produkt, dass die wenigsten von uns aus guten Gründen nicht nutzen.
Gruß Peter
Beitragvon Zaphod.Beeblebrox » 26.01.2011, 13:47
ich habe nicht den ESX gebootet, sondern nur die virtuelle Maschine neu gestartet, daher kommen die logfiles.
Ich habe den Storage mit WinSCP angeschaut, daher die Dateien auf dem Storage.
JETZT werde ich dann mal mit Knoppix booten und versuchen, die Platte zu mounten, wie auch immer das gehen mag.
Nein, die Maschine hatte nur eine virtuelle Festplatte, wären es zwei oder mehr gewesen , hätte ich es erwähnt, so viel habe ich hier verstanden!
Sicher ist VDR speziell, aber es wurde uns von unserem Dienstleister empfohlen.
WAS könnt Ihr denn empfeheln für 3 ESX Server und 30 virtuelle Maschinen?
Beitragvon PeterDA » 26.01.2011, 14:12
Dann solltest du diesen Spezialisten mal mit dem Problem konfrontieren!
Ich habe bis jetzt nur gute Erfahrungen mit vRanger
Gruß Peter
Beitragvon JMcClane » 26.01.2011, 14:23
Ich hab gute Erfahrungen mit Veeam gemacht. vRanger habe ich mal ein einer früheren Version eingesetzt und zu der Zeit war es eine mehr oder weniger gute GUI für VCB.
Beitragvon irix » 26.01.2011, 15:17
JMcClane hat geschrieben:Ich hab gute Erfahrungen mit Veeam gemacht. vRanger habe ich mal ein einer früheren Version eingesetzt und zu der Zeit war es eine mehr oder weniger gute GUI für VCB.
Das ist aber schon lange her :)
Der Scharm bei VMware DR ist ja das es die meisten Kunden mitbezahlt haben, die Deduplizierungs Geschichte und die Integration mit der WebGUI ins vCenter.
Wenn es jetzt noch funktionieren wuerde.......
Beitragvon Zaphod.Beeblebrox » 26.01.2011, 16:02
[quote="PeterDA"]Dann solltest du diesen Spezialisten mal mit dem Problem konfrontieren!
[quote]
Gute Idee, der Kollege befindet sich nur gerade in Urlaub, daher wende ich mich an Euch!
Eben , es war ein gratis goodie und lief ja zumindest in die eine Richtung, die Richtung des Backups geht ja... NUR zurück nicht wirklich, anscheinend!
Wie mache ich einen Call bei VMWare auf?
geht das per WEB und Mail?
Beitragvon Zaphod.Beeblebrox » 26.01.2011, 16:04
OK, habe von Knoppix gebootet.
wie kann ich jetzt die Festplatte mounten?
... und zitieren kann ich auch nicht!
Beitragvon Zaphod.Beeblebrox » 26.01.2011, 16:22
OK, habe dann mal gparted genommen.
Partition nicht zugeteilt
Dateisystem nicht zugeteilt
/dev/sda: unrecognised disk label
liest sich nicht jut!
Beitragvon continuum » 26.01.2011, 18:37
Dann ist booten von knoppix angesagt.
Nach dem start installier "testdisk" - das findet die Partitionen wieder wenn du Glueck hast
Zurück zu „vSphere 4 / ESX 4“
