help please, deleted the flat file i have only snapshot
snapshot
Beitragvon thinos » 18.01.2010, 21:32
Edited SERVER2_1.vmsd
.encoding = "UTF-8"
snapshot.lastUID = "2"
snapshot.numSnapshots = "2"
snapshot.current = "2"
snapshot0.uid = "1"
snapshot0.filename = "SERVER-Snapshot1.vmsn"
snapshot0.displayName = "Po nainstalovani vsetkeho"
snapshot0.description = ""
snapshot0.createTimeHigh = "292360"
snapshot0.createTimeLow = "-1923241683"
snapshot0.numDisks = "1"
snapshot0.disk0.fileName = "SERVER2_1.vmdk"
snapshot0.disk0.node = "scsi0:0"
snapshot1.uid = "2"
snapshot1.filename = "SERVER-Snapshot2.vmsn"
snapshot1.parent = "1"
snapshot1.displayName = "test2"
snapshot1.description = ""
snapshot1.createTimeHigh = "292360"
snapshot1.createTimeLow = "-1873802864"
snapshot1.numDisks = "1"
snapshot1.disk0.fileName = "SERVER2_1-000001.vmdk"
snapshot1.disk0.node = "scsi0:0"
Beitragvon thinos » 18.01.2010, 22:37
what should i do next?
Beitragvon continuum » 18.01.2010, 23:00
what is the current state ?
in last post I forgot that you should delete the vmsd-file.
Can you upload the vmware.log from a start attemptafter you deleted the vmsd-file to ifile.it
Beitragvon thinos » 19.01.2010, 00:00
i cannot start the wm the pc freezes, where are the vm-workstation logs? i cannot find the logs in current dir
before i started the vm, without problems
one question, i have downloaded all the files to a external hdd. the original server is esxi. can it be that i need to do this on the esxi, my pc has vm-workstation
Beitragvon continuum » 19.01.2010, 01:12
It can be done from Workstation as well - but that is a little more advanced.
Anyway - you should find a vmware.log next to the vmx-file - same dir.
Which Workstation do you use ? I only tested this with WS 6.5.3 on a Windows 2003 host.
It should be easier to do that on the ESXi ....
Beitragvon thinos » 19.01.2010, 07:26
vmworkstation ist v. 6.5.7
http://ifile.it/9x62lmh
Zurück zu „ESXi 4“
