ESXi5 in VMserver1.0.10
Beitragvon Dayworker » 09.09.2012, 20:13
Sieht soweit noch ganz gut aus, aber ich scheitere jedes Mal an folgendem Bootbank-Problem:
Geändert gegenüber der ESXi4-Inst habe ich nur den GastOS-Typ, hier die VMX:
bios.bootdelay = "5000"
config.version = "8"
virtualHW.version = "4"
displayName = "esxi5"
guestOS = "other-64"
### 2 CPUs (eine genügt auch):
numvcpus = "2"
### RAM entsprechend Host-Ausstattung anpassen:
memsize = "2048"
###Intel:
monitor_control.vt32 = "TRUE"
###AMD:
monitor_control.enable_svm = "TRUE"
###CPU-unabhängig immer notwendig:
monitor_control.restrict_backdoor = "TRUE"
###Tuning:
isolation.tools.hgfs.disable = "TRUE"
sched.mem.pshare.enable = "FALSE"
mainmem.useNamedFile = "FALSE"
MemTrimRate=0
###LSIlogic-Adapter:
scsi0.present = "TRUE"
scsi0.virtualDev = "lsilogic"
scsi0.pciSlotNumber = "16"
###Systemplatte des ESX Servers (nur für System gänge auch IDE, für VMFS nicht):
scsi0:0.present = "TRUE"
scsi0:0.fileName = "ESXi5_system.vmdk"
scsi0:0.redo = ""
###ISO-Image der ESX Installation:
ide1:0.present = "TRUE"
ide1:0.fileName = "VMware-VMvisor-Installer-5.0.0.update01-623860.x86_64.iso"
### Ethernet Intel 1000
### Netzwerke VMnetX eventuell anpassen
ethernet0.present = "TRUE"
ethernet0.connectionType = "custom"
ethernet0.vnet = "VMnet0"
ethernet0.generatedAddress = "00:0c:29:7f:a5:2e"
ethernet1.present = "TRUE"
ethernet1.startConnected = "FALSE"
ethernet1.virtualDev = "e1000"
ethernet1.connectionType = "custom"
ethernet1.vnet = "VMnet2"
ethernet1.pciSlotNumber = "34"
ethernet1.addressType = "generated"
ethernet1.generatedAddress = "00:0c:29:7f:a5:38"
ethernet1.generatedAddressOffset = "10"
ethernet2.present = "FALSE"
ethernet2.startConnected = "TRUE"
ethernet2.virtualDev = "e1000"
ethernet2.connectionType = "custom"
ethernet2.vnet = "VMnet8"
ethernet2.pciSlotNumber = "35"
ethernet2.addressType = "generated"
ethernet2.generatedAddress = "00:0c:29:30:39:12"
ethernet2.generatedAddressOffset = "20"
ethernet3.present = "FALSE"
ethernet3.startConnected = "TRUE"
ethernet3.virtualDev = "e1000"
ethernet3.connectionType = "custom"
ethernet3.vnet = "VMnet8"
ethernet3.pciSlotNumber = "36"
ethernet3.addressType = "generated"
ethernet3.generatedAddress = "00:0c:29:30:39:1c"
ethernet3.generatedAddressOffset = "30"
###sonstiges:
floppy0.autodetect = "TRUE"
floppy0.fileName = "vmscsi-1.2.0.4.flp"
usb.present = "FALSE"
ehci.present = "FALSE"
ehci.pciSlotNumber = "33"
sound.present = "FALSE"
sound.fileName = "-1"
sound.autodetect = "TRUE"
svga.autodetect = "TRUE"
pciBridge0.present = "TRUE"
mks.keyboardFilter = "allow"
nvram = "ESXi5.nvram"
tools.remindInstall = "FALSE"
uuid.location = "56 4d 70 a6 73 82 4a c7-6d 5e 33 55 9b 7f a5 2e"
uuid.bios = "56 4d 70 a6 73 82 4a c7-6d 5e 33 55 9b 7f a5 2e"
floppy0.fileType = "file"
autostop = "poweroff"
workingDir = "."
priority.grabbed = "normal"
priority.ungrabbed = "normal"
Beitragvon Dayworker » 09.09.2012, 20:44
Da ich kein Freund von Aufgeben bin, habe ich die VMX auf IDE fürs System und SCSI für den DS umgestrickt. Sie sieht somit folgendermaßen aus:
numvcpus = "2"
memsize = "2048"
###Intel:
###AMD:
###Tuning:
MemTrimRate=0
ide0:0.fileName = "ESXi5_system.vmdk"
ide0:0.present = "TRUE"
ide0:0.redo = ""
ide0:0.startConnected = "TRUE"
scsi1.pciSlotNumber = "16"
scsi1.present = "TRUE"
scsi1.virtualDev = "lsilogic"
scsi1:1.fileName = "ESXi5_datastore.vmdk"
scsi1:1.present = "TRUE"
scsi1:1.redo = ""
ethernet1.present = "FALSE"
ethernet1.startConnected = "TRUE"
###sonstiges:
workingDir = "."
Jetzt fehlt mir nur noch Jörgs Standardspruch:
irix hat geschrieben:Tja,
"Kaum macht man es richtig.... schon funktioniert es[tm]"
Beitragvon Dayworker » 09.09.2012, 21:11
Falls jemand den Vi/vSphere-Client runterladen will und sich dabei über die lahme Downloadgeschwindigkeit wundert. Der Client wird jetzt nicht mehr lokal sondern direkt bei VMware und passend zur installierten Version runtergeladen.
In meinem Fall lautet die Adresse daher http://vsphereclient.vmware.com/vsphereclient/6/2/3/3/7/3/VMware-viclient-all-5.0.0-623373.exe und die ~350MB dauern bei einer schmalen DSL-Anbindung natürlich nicht unwesentlich länger... :evil:
Weshalb der Download sich jetzt gegenüber den älteren ESXi-Version mehr als verdoppelt hat, wird dann Gegenstand eines weiteren Postings sein.
Beitragvon Dayworker » 03.10.2012, 16:15
Den ESXi5 kann man mit dem Bootparameter "formatwithmbr" auch zur MBR-Verwendung zwingen.
Ob die ESXi5-Inst dann damit unter VMserver1 und reinem SCSI durchläuft, wird Gegenstand eines weiteren Tests werden.
Beitragvon Dayworker » 19.01.2013, 18:07
Ich hab mich wieder mal mit dem ESXi5 unter VMserver1.010 beschäftigt und versuche noch immer eine Inst mit dem LSI-SCSI-Controller hinzubekommen. Dabei fällt mir allerdings erneut auf, daß ich bei der Auswahl des Storagemediums zweimal das gleiche Laufwerk angezeigt bekomme:
Einziger Unterschied sind die zwei verschiedenen LUN-Nummern mpx.vmhba1:C0:T1:L0 und mpx.vmhba1:C0:T1:L32. Weiß jemand, was der ESXi5 mir damit sagen will?
