ESXi4 in VMserver1.0.10
Beitragvon Dayworker » 09.09.2012, 13:00
Hier die VMX:
bios.bootdelay = "5000"
config.version = "8"
virtualHW.version = "4"
displayName = "esxi4"
guestOS = "other"
### 2 CPUs (eine genügt auch):
numvcpus = "2"
### RAM entsprechend Host-Ausstattung anpassen:
memsize = "2048"
###Intel:
monitor_control.vt32 = "TRUE"
###AMD:
monitor_control.enable_svm = "TRUE"
###CPU-unabhängig immer notwendig:
monitor_control.restrict_backdoor = "TRUE"
###Tuning:
isolation.tools.hgfs.disable = "TRUE"
sched.mem.pshare.enable = "FALSE"
mainmem.useNamedFile = "FALSE"
MemTrimRate=0
###LSIlogic-Adapter:
scsi0.present = "TRUE"
scsi0.virtualDev = "lsilogic"
scsi0.pciSlotNumber = "16"
###Systemplatte des ESX Servers (nur für System gänge auch IDE, für VMFS nicht):
scsi0:0.present = "TRUE"
scsi0:0.fileName = "ESXi4_system.vmdk"
scsi0:0.redo = ""
###ISO-Image der ESX Installation:
ide1:0.present = "TRUE"
ide1:0.fileName = "VMware-VMvisor-Installer-4.0.0.Update01-208167.x86_64.iso"
### Ethernet Intel 1000
### Netzwerke VMnetX eventuell anpassen
ethernet0.present = "TRUE"
ethernet0.connectionType = "custom"
ethernet0.vnet = "VMnet0"
ethernet0.generatedAddress = "00:0c:29:01:a7:a6"
ethernet1.present = "TRUE"
ethernet1.startConnected = "FALSE"
ethernet1.virtualDev = "e1000"
ethernet1.connectionType = "custom"
ethernet1.vnet = "VMnet2"
ethernet1.pciSlotNumber = "34"
ethernet1.addressType = "generated"
ethernet1.generatedAddress = "00:0c:29:01:a7:b0"
ethernet1.generatedAddressOffset = "10"
ethernet2.present = "FALSE"
ethernet2.startConnected = "TRUE"
ethernet2.virtualDev = "e1000"
ethernet2.connectionType = "custom"
ethernet2.vnet = "VMnet8"
ethernet2.pciSlotNumber = "35"
ethernet2.addressType = "generated"
ethernet2.generatedAddress = "00:0c:29:30:39:12"
ethernet2.generatedAddressOffset = "20"
ethernet3.present = "FALSE"
ethernet3.startConnected = "TRUE"
ethernet3.virtualDev = "e1000"
ethernet3.connectionType = "custom"
ethernet3.vnet = "VMnet8"
ethernet3.pciSlotNumber = "36"
ethernet3.addressType = "generated"
ethernet3.generatedAddress = "00:0c:29:30:39:1c"
ethernet3.generatedAddressOffset = "30"
###sonstiges:
floppy0.autodetect = "TRUE"
floppy0.fileName = "vmscsi-1.2.0.4.flp"
usb.present = "FALSE"
ehci.present = "FALSE"
ehci.pciSlotNumber = "33"
sound.present = "FALSE"
sound.fileName = "-1"
sound.autodetect = "TRUE"
svga.autodetect = "TRUE"
pciBridge0.present = "TRUE"
mks.keyboardFilter = "allow"
nvram = "ESXi4.nvram"
tools.remindInstall = "FALSE"
uuid.location = "56 4d f6 e4 80 6c 68 e9-df 10 da 21 7c 01 a7 a6"
uuid.bios = "56 4d f6 e4 80 6c 68 e9-df 10 da 21 7c 01 a7 a6"
floppy0.fileType = "file"
autostop = "poweroff"
workingDir = "."
priority.grabbed = "normal"
priority.ungrabbed = "normal"
