Konfiguration IPCop-VM mit Huawei E169g USB-Stick (O2)
Beitragvon e-e-e » 31.10.2009, 17:47
ich krampfe gerade an der Konfiguration einer IPCop-VM.
Ich wollte über den Cop alternativ zum DSL ins Internet, da hier im Hause öfter mal an der Telefonverkabelung geschraubt wird und man dann eben mal einem ganzen Tag kein Telefon und Internet hat.
In der vmware.log tritt aber ein Fehler auf, mit dem ich absolut nichts anfangen kann:
Oct 31 17:20:48: vmx| DICT --- USER DEFAULTS
Oct 31 17:20:48: vmx| DICT --- HOST DEFAULTS
Oct 31 17:20:48: vmx| DICT vmnet1.hostonlyaddress = 172.16.124.1
Oct 31 17:20:48: vmx| DICT serverd.init.fullpath = /usr/lib/vmware/serverd/init.pl
Oct 31 17:20:48: vmx| DICT authd.client.port = 904
Oct 31 17:20:48: vmx| DICT control.fullpath = /usr/bin/vmware-cmd
Oct 31 17:20:48: vmx| DICT authd.fullpath = /usr/sbin/vmware-authd
Oct 31 17:20:48: vmx| DICT loop.fullpath = /usr/bin/vmware-loop
Oct 31 17:20:48: vmx| DICT libdir = /usr/lib/vmware
Oct 31 17:20:48: vmx| DICT vmware.fullpath = /usr/bin/vmware
Oct 31 17:20:48: vmx| DICT vmnet1.hostonlynetmask = 255.255.255.0
Oct 31 17:20:48: vmx| DICT vmdir = /home/vmware
Oct 31 17:20:48: vmx| DICT dhcpd.fullpath = /usr/bin/vmnet-dhcpd
Oct 31 17:20:48: vmx| DICT serverd.fullpath = /usr/sbin/vmware-serverd
Oct 31 17:20:48: vmx| DICT datastore.name = local
Oct 31 17:20:48: vmx| DICT datastore.localpath = /home/vmware/
Oct 31 17:20:48: vmx| DICT sched.mem.pshare.enable = FALSE
Oct 31 17:20:48: vmx| DICT prefvmx.minVmMemPct = 100
Oct 31 17:20:48: vmx| DICT prefvmx.useRecommendedLockedMemSize = TRUE
Oct 31 17:20:48: vmx| DICT mainMem.partialLazyRestore = FALSE
Oct 31 17:20:48: vmx| DICT mainMem.partialLazySave = FALSE
Oct 31 17:20:48: vmx| DICT vm.swappiness = 0
Oct 31 17:20:48: vmx| DICT --- SITE DEFAULTS
Oct 31 17:20:48: vmx| DICT tag.help = introduction.htm
Oct 31 17:20:48: vmx| DICT tag.configurationEditor = config_editor_newvm.htm
Oct 31 17:20:48: vmx| DICT tag.ideConfig = devices_virtualdrive.htm
Oct 31 17:20:48: vmx| DICT tag.floppyConfig = devices_floppy.htm
Oct 31 17:20:48: vmx| DICT tag.mouseConfig = devices_mouse.htm
Oct 31 17:20:48: vmx| DICT tag.netConfig = devices_netadapter.htm
Oct 31 17:20:48: vmx| DICT tag.parallelConfig = devices_parallel.htm
Oct 31 17:20:48: vmx| DICT tag.serialConfig = devices_serial.htm
Oct 31 17:20:48: vmx| DICT tag.soundConfig = devices_sound.htm
Oct 31 17:20:48: vmx| DICT tag.memConfig = configvm_memory.htm
Oct 31 17:20:48: vmx| DICT tag.miscConfig = configvm.htm
Oct 31 17:20:48: vmx| DICT tag.usbConfig = devices_usb.htm
Oct 31 17:20:48: vmx| DICT tag.displayConfig = configvm_display-problems.htm
Oct 31 17:20:48: vmx| DICT tag.tools = vmtools.htm
Oct 31 17:20:48: vmx| DICT --- COMMAND LINE
Oct 31 17:20:48: vmx| DICT gui.managementUI = TRUE
Oct 31 17:20:48: vmx| DICT --- CONFIGURATION
Oct 31 17:20:48: vmx| DICT config.version = 8
Oct 31 17:20:48: vmx| DICT virtualHW.version = 4
Oct 31 17:20:48: vmx| DICT scsi0.present = TRUE
Oct 31 17:20:48: vmx| DICT memsize = 256
Oct 31 17:20:48: vmx| DICT ide0:0.present = TRUE
Oct 31 17:20:48: vmx| DICT ide0:0.fileName = IPCop_SurfStick.vmdk
Oct 31 17:20:48: vmx| DICT ide0:0.writeThrough = TRUE
Oct 31 17:20:48: vmx| DICT ide1:0.present = TRUE
Oct 31 17:20:48: vmx| DICT ide1:0.fileName = /tmp/IPCop_SurfStick/IPCop-Addons.iso
Oct 31 17:20:48: vmx| DICT ide1:0.deviceType = cdrom-image
Oct 31 17:20:48: vmx| DICT floppy0.fileName = /dev/fd0
Oct 31 17:20:48: vmx| DICT Ethernet0.present = TRUE
Oct 31 17:20:48: vmx| DICT displayName = IPCop_SurfStick
Oct 31 17:20:48: vmx| DICT guestOS = otherlinux
Oct 31 17:20:48: vmx| DICT priority.grabbed = normal
Oct 31 17:20:48: vmx| DICT priority.ungrabbed = normal
Oct 31 17:20:48: vmx| DICT powerType.powerOff = hard
Oct 31 17:20:48: vmx| DICT powerType.powerOn = hard
Oct 31 17:20:48: vmx| DICT powerType.suspend = hard
Oct 31 17:20:48: vmx| DICT powerType.reset = hard
Oct 31 17:20:48: vmx| DICT floppy0.startConnected = FALSE
Oct 31 17:20:48: vmx| DICT ide0:0.redo =
Oct 31 17:20:48: vmx| DICT ethernet0.addressType = generated
Oct 31 17:20:48: vmx| DICT uuid.location = 56 4d 76 52 97 2a df 8d-a5 67 ed 4f 7a d4 7b 70
Oct 31 17:20:48: vmx| DICT uuid.bios = 56 4d 76 52 97 2a df 8d-a5 67 ed 4f 7a d4 7b 70
Oct 31 17:20:48: vmx| DICT ethernet0.generatedAddress = 00:0c:29:d4:7b:70
Oct 31 17:20:48: vmx| DICT ethernet0.generatedAddressOffset = 0
Oct 31 17:20:48: vmx| DICT usb.present = TRUE
Oct 31 17:20:48: vmx| DICT usb.generic.autoconnect = FALSE
Oct 31 17:20:48: vmx| DICT usb.autoConnect.device0 = path:5/0 autoclean:1
Oct 31 17:20:48: vmx| DICT ide1:0.startConnected = FALSE
Oct 31 17:20:48: vmx| DICT checkpoint.vmState =
Oct 31 17:20:48: vmx| DICT --- GLOBAL SETTINGS
Oct 31 17:20:48: vmx| Msg_Hint: msg.hostlinux.othervms (not shown)
Oct 31 17:20:48: vmx| WSSCAN: reserved mem (in MB) min=32 max=7904 recommended=7904
Oct 31 17:20:48: vmx| hostMem=8000 maxAllowedAll=-1 maxAllowedVM=3600
Oct 31 17:20:48: vmx| totOverhead=16
Oct 31 17:20:48: vmx| WSSCAN: used rec mem (in MB) 7904
Oct 31 17:20:48: vmx| WSSCAN: Overhead 71921 paged 5534 nonpaged 4096 maxFBSize
Oct 31 17:20:48: vmx| WSSCAN 9 1314590 2023424 -1 2023424 -1 100 1454084
Oct 31 17:20:48: vmx| LICENSE using: '/etc/vmware/license.vs.1.0-00'
Oct 31 17:20:48: vmx| STATDECLGROUP stats Root "" null
Oct 31 17:20:48: vmx| Host CPUID features: version 0x6f8 id1.edx 0xbfebfbff id1.ecx 0xe3bd id81.edx 0x20100800 id81.ecx 0x1
Oct 31 17:20:48: vmx| CPU.cpuFeatures = 0xb971ff37
Oct 31 17:20:48: vmx| CPUID after masking: version 0x6f8 id1.edx 0xfebfbff id1.ecx 0xa215 id81.edx 0x20100800 id81.ecx 0x1 id88.ecx 0x0
Oct 31 17:20:48: vmx| CPU.cpuFeatures = 0x9871ff33
Oct 31 17:20:48: vmx| APIC: Local APIC at 0xfee00000
Oct 31 17:20:48: vmx| KHZEstimate 2400000
Oct 31 17:20:48: vmx| MHZEstimate 2400
Oct 31 17:20:48: vmx| NumVCPUs 1
Oct 31 17:20:48: vmx| UUID: location-UUID is 56 4d 76 52 97 2a df 8d-a5 67 ed 4f 7a d4 7b 70
Oct 31 17:20:48: vmx| MM: Using partialmap, 65536 pages AC 0 CE 1 TM 0 DOHU 0
Oct 31 17:20:48: vmx| UUID: canonical path is /tmp/IPCop_SurfStick/IPCop_SurfStick.vmx
Oct 31 17:20:48: vmx| MM: using fileName /tmp/IPCop_SurfStick/564d7652-972a-df8d-a567-ed4f7ad47b70.vmem for paging
Oct 31 17:20:48: vmx| Msg_Reset:
Oct 31 17:20:48: vmx| ----------------------------------------
Oct 31 17:20:48: vmx| Opened paging file /tmp/IPCop_SurfStick/564d7652-972a-df8d-a567-ed4f7ad47b70.vmem
Oct 31 17:20:48: vmx| Mapped mainmem as pageable
Oct 31 17:20:48: vmx| MStat: Creating Stat vm.cpuusage
Oct 31 17:20:48: vmx| MStat: Creating Stat vm.ram
Oct 31 17:20:48: vmx| MStat: Creating Stat vm.uptime
Oct 31 17:20:48: vmx| DISK: OPEN ide0:0 '/tmp/IPCop_SurfStick/IPCop_SurfStick.vmdk' persistent R[(null)]
Oct 31 17:20:48: vmx| AIOGNRC: Starting 4 I/O threads.
Oct 31 17:20:48: vmx| DISKLIB-DSCPTR: Opened [0]: "IPCop_SurfStick-s001.vmdk" (0x2a)
Oct 31 17:20:48: vmx| DISKLIB-DSCPTR: Opened [1]: "IPCop_SurfStick-s002.vmdk" (0x2a)
Oct 31 17:20:48: vmx| DISKLIB-DSCPTR: Opened [2]: "IPCop_SurfStick-s003.vmdk" (0x2a)
Oct 31 17:20:48: vmx| DISKLIB-DSCPTR: Opened [3]: "IPCop_SurfStick-s004.vmdk" (0x2a)
Oct 31 17:20:48: vmx| DISKLIB-DSCPTR: Opened [4]: "IPCop_SurfStick-s005.vmdk" (0x2a)
Oct 31 17:20:48: vmx| DISKLIB-LINK : Opened '/tmp/IPCop_SurfStick/IPCop_SurfStick.vmdk' (0x2a): twoGbMaxExtentSparse, 16777216 sectors / 8192 Mb.
Oct 31 17:20:48: vmx| DISKLIB-LIB : Opened "/tmp/IPCop_SurfStick/IPCop_SurfStick.vmdk" (flags 0x2a).
Oct 31 17:20:48: vmx| DISK: OPEN '/tmp/IPCop_SurfStick/IPCop_SurfStick.vmdk' Geo (16383/16/63) BIOS Geo (1044/255/63) freeSpace=71545Mb
Oct 31 17:20:48: vmx| TimeTracker host to guest rate conversion 4229058351592881 @ 2400000000Hz -> 4229058351592881 @ 2400000000Hz
Oct 31 17:20:48: vmx| TimeTracker host to guest rate conversion ((x * 2147483648) >> 31) + 0
Oct 31 17:20:48: vmx| MStat: Creating Stat ide0:0.bytesread
Oct 31 17:20:48: vmx| MStat: Creating Stat ide0:0.byteswritten
Oct 31 17:20:48: vmx| MStat: Creating Stat ide1:0.bytesread
Oct 31 17:20:48: vmx| MStat: Creating Stat ide1:0.byteswritten
Oct 31 17:20:48: vmx| SCSI0: UNTAGGED commands will be converted to ORDER tags.
Oct 31 17:20:48: vmx| MStat: Creating Stat vm.heartbeat
Oct 31 17:20:48: vmx| DISKUTIL: ide0:0 : toolsVersion = 0
Oct 31 17:20:48: vmx| DISKUTIL: Offline toolsVersion = 0
Oct 31 17:20:48: vmx| TOOLS INSTALL initializing state to IDLE on power on.
Oct 31 17:20:48: vmx| DVGA: DVGA is not supported since the host uses kernel framebuffer
Oct 31 17:20:48: vmx| DVGA: Full screen VGA will not be available.
Oct 31 17:20:48: vmx| USB: Initializing UHCI host controller
Oct 31 17:20:48: vmx| USB: Initializing USB Generic backend
Oct 31 17:20:48: vmx| USBGL: CONTROL failed -1:71:Protocol error
Oct 31 17:20:48: vmx| requesttype=80 request=6 value=300 index=0
Oct 31 17:20:48: vmx| length=4 data=0xffcfe05c timeout=3e8
Oct 31 17:20:48: vmx| USB: Search for USB devices to connect [path:5/0 autoclean:1]
Oct 31 17:20:48: vmx| VMMon_GetkHzEstimate: Calculated 2402915 kHz
Oct 31 17:20:48: vmx| VLANCE: send cluster threshold is 80, size = 2 recalcInterval is 2 ticks
Oct 31 17:20:48: vmx| MStat: Creating Stat ethernet0.bytesread
Oct 31 17:20:48: vmx| MStat: Creating Stat ethernet0.byteswritten
Oct 31 17:20:48: vmx| Ethernet0 MAC Address: 00:0c:29:d4:7b:70
Oct 31 17:20:48: vmx| VMXNET: send cluster threshold is 80, size = 2 recalcInterval is 2 ticks, dontClusterSize is 128
Oct 31 17:20:48: vmx| E1000: checksum cycles/kB: C=742 asm=676
Oct 31 17:20:48: vmx| VMX_PowerOn: ModuleTable_PowerOn = 1
Oct 31 17:20:48: vmx| VMX setting maximum IPC write buffers to 0 packets, 0 bytes
Oct 31 17:20:48: mks| Async MKS thread is alive
Oct 31 17:20:48: vmx| CnxAcceptConnection: Could not receive fd on 156: invalid control message
Oct 31 17:20:48: vmx| Failed to get IPC connection
Oct 31 17:20:48: vcpu-0| APIC: version = 0x14, max LVT = 5
Oct 31 17:20:48: vcpu-0| APIC: LDR = 0x2000000, DFR = 0xffffffff
Oct 31 17:20:48: vcpu-0| PShare: enabled 0, scanRate 32, checkRate 16
Oct 31 17:20:48: vcpu-0| guestCpuFeatures = 0x9871ff33
Oct 31 17:20:48: vcpu-0| Init modules.
Oct 31 17:20:48: vcpu-0| DISKUTIL: ide0:0 : capacity=16777216
Oct 31 17:20:48: vcpu-0| CPU reset: hard
Oct 31 17:20:48: vmx| VNET: Notification enabled for Ethernet0
Oct 31 17:20:48: vmx| USB: Found device [name:Anonymous\ USB\ Device\ (Vendor:12d1\ Product:1001) vid:12d1 pid:1001 path:5/0]
Oct 31 17:20:48: vmx| USB: Autoconnecting device "Anonymous USB Device (Vendor:12d1 Product:1001)" matching pattern [path:5/0 autoclean:1]
Oct 31 17:20:48: vmx| USB: Connecting device 0xe005000712d11001
Oct 31 17:20:48: vmx| USB: Found device [name:Mustek\ Systems\ USB\ device vid:055f pid:0006 path:2/0]
Oct 31 17:20:48: vmx| USB: Found device [name:TDi\ GmbH\ -\ Germany\ Lockware\ USB-Key vid:0e50 pid:0100 path:2/1]
Oct 31 17:20:48: vmx| VMXVmdbLoadUsbDevices: New set of 3 USB devices
Oct 31 17:20:48: vmx| length=4 data=0xffcfbefc timeout=3e8
Oct 31 17:20:48: vmx| USB: Found device [name:Anonymous\ USB\ Device\ (Vendor:12d1\ Product:1001) vid:12d1 pid:1001 port:1 path:5/0]
Oct 31 17:20:48: vmx| USB: Device [name:Anonymous\ USB\ Device\ (Vendor:12d1\ Product:1001) vid:12d1 pid:1001 port:1 path:5/0] should already be connected
Oct 31 17:20:48: vcpu-0| sz=3112288
Oct 31 17:20:48: vcpu-0| vmm32 initialized: Releasebuild-91891. cflags: 0x08000002.01c41000.00000150
Oct 31 17:20:48: vmx| Accepted new connection at 182 for thread servercontrol (0x84d1360)
Oct 31 17:20:48: vmx| VUINewControlConnection: before slow ACL gunk (bug 63252).
Oct 31 17:20:48: vmx| ACL_InitCapabilities: here 2 (bug 63252)
Oct 31 17:20:48: vmx| VUINewControlConnection: after slow ACL gunk (bug 63252).
Oct 31 17:20:48: vmx| VUI: A new VMControl client connected.
Oct 31 17:20:48: vmx| IPC version negotiation version: VMX returning 2.1 to servercontrol
Oct 31 17:20:48: vmx| IPC vmcontrol-temp version: VMX returning 11.4 to servercontrol that tried 11.4
Oct 31 17:20:48: vcpu-0| SVGA: Registering MemSpace at 0xf0000000(0x0) and 0xec000000(0x0)
Oct 31 17:20:48: vcpu-0| SVGA: Unregistering MemSpace at 0xf0000000(0xf0000000) and 0xec000000(0xec000000)
Oct 31 17:20:48: vcpu-0| SVGA: Registering MemSpace at 0xf0000000(0xf0000000) and 0xec000000(0xec000000)
Oct 31 17:20:48: vcpu-0| SVGA: Registering IOSpace at 0x1420 (0x0)
Oct 31 17:20:48: mks| Connecting to window system.
Oct 31 17:20:48: mks| XINFO X fd is 41
Oct 31 17:20:48: mks| XINFO depth 24 bpp 32 class 4
Oct 31 17:20:48: mks| XINFO WARNING: XF86MISC version 0.9
Oct 31 17:20:48: mks| VT redirected kernel output to /dev/tty1
Oct 31 17:20:48: mks| rasterops MMXEXT accelerations enabled
Oct 31 17:20:48: mks| XINFO unsupported XF86VidMode version: 2.2
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 0: 2048x1536 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 1: 1920x1440 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 2: 1920x1200 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 3: 1904x1200 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 4: 1600x1200 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 5: 1680x1050 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 6: 1600x1024 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 7: 1600x1000 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 8: 1400x1050 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 9: 1280x1024 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 10: 1440x900 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 11: 1280x960 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 12: 1368x768 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 13: 1280x800 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 14: 1152x864 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 15: 1280x768 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 16: 1024x768 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 17: 1280x600 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 18: 1024x600 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 19: 800x600 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 20: 768x576 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 21: 640x480 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 22: 2048x1536 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 23: 2048x1536 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 24: 1920x1440 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 25: 1920x1440 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 26: 1856x1392 flags: 0x6
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 27: 1856x1392 flags: 0x6
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 28: 1792x1344 flags: 0x6
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 29: 1792x1344 flags: 0x6
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 30: 1920x1200 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 31: 1920x1200 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 32: 1904x1200 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 33: 1904x1200 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 34: 1600x1200 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 35: 1600x1200 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 36: 1680x1050 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 37: 1680x1050 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 38: 1600x1024 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 39: 1600x1024 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 40: 1600x1000 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 41: 1600x1000 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 42: 1400x1050 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 43: 1400x1050 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 44: 1280x1024 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 45: 1280x1024 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 46: 1440x900 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 47: 1440x900 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 48: 1280x960 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 49: 1280x960 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 50: 1368x768 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 51: 1368x768 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 52: 1280x800 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 53: 1280x800 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 54: 1152x864 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 55: 1152x864 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 56: 1280x768 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 57: 1280x768 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 58: 1152x768 flags: 0x5
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 59: 1024x768 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 60: 1024x768 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 61: 1280x600 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 62: 1280x600 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 63: 960x720 flags: 0x26
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 64: 960x720 flags: 0x26
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 65: 928x696 flags: 0x26
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 66: 928x696 flags: 0x26
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 67: 1024x600 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 68: 1024x600 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 69: 896x672 flags: 0x26
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 70: 896x672 flags: 0x26
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 71: 832x624 flags: 0xa
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 72: 800x600 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 73: 800x600 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 74: 768x576 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 75: 768x576 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 76: 700x525 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 77: 700x525 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 78: 640x512 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 79: 640x512 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 80: 640x512 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 81: 640x480 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 82: 640x480 flags: 0x0
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 83: 720x400 flags: 0x6
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 84: 640x400 flags: 0x6
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 85: 576x432 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 86: 640x350 flags: 0x9
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 87: 576x384 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 88: 512x384 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 89: 512x384 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 90: 512x384 flags: 0x2a
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 91: 512x384 flags: 0x2a
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 92: 512x384 flags: 0x35
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 93: 416x312 flags: 0x2a
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 94: 400x300 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 95: 400x300 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 96: 400x300 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 97: 400x300 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 98: 400x300 flags: 0x25
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 99: 320x240 flags: 0x2a
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 100: 320x240 flags: 0x2a
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 101: 320x240 flags: 0x2a
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 102: 320x240 flags: 0x2a
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 103: 360x200 flags: 0x26
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 104: 320x200 flags: 0x26
Oct 31 17:20:48: mks| XINFO XFree86 VidMode 105: 320x175 flags: 0x29
Oct 31 17:20:48: mks| Ignoring update request in VGA_Expose (mode change pending).
Oct 31 17:20:48: vcpu-0| UHCI: Global Reset
Oct 31 17:20:48: vcpu-0| UHCI: HCReset
Oct 31 17:20:48: vmx| USBGL: Unhandle status -71
Oct 31 17:21:20: vcpu-0| VIDE: Curr CHS info cyls: 17475 heads: 15 sects: 63 lba_cap: 16777216
Oct 31 17:21:21: vcpu-0| BIOS-UUID is 56 4d 76 52 97 2a df 8d-a5 67 ed 4f 7a d4 7b 70
Oct 31 17:21:21: vcpu-0| DISKUTIL: ide0:0 : toolsVersion = 0
Oct 31 17:21:21: vcpu-0| DISKUTIL: Offline toolsVersion = 0
Oct 31 17:21:21: mks| Ignoring update request in VGA_Expose (mode change pending).
Oct 31 17:21:22: vcpu-0| VIDE: Curr CHS info cyls: 17475 heads: 15 sects: 63 lba_cap: 16777216
Oct 31 17:21:22: mks| Ignoring update request in VGA_Expose (mode change pending).
Oct 31 17:21:28: mks| Ignoring update request in VGA_Expose (mode change pending).
Oct 31 17:21:28: vcpu-0| SVGA: Unregistering IOSpace at 0x1420 (0x1420)
Oct 31 17:21:28: vcpu-0| SVGA: Registering IOSpace at 0xfff0 (0x0)
Oct 31 17:21:28: vcpu-0| SVGA: Unregistering IOSpace at 0xfff0 (0xfff0)
Oct 31 17:21:28: vcpu-0| SVGA: Registering IOSpace at 0x1420 (0x0)
Oct 31 17:21:42: vcpu-0| VIDE: Curr CHS info cyls: 17475 heads: 15 sects: 63 lba_cap: 16777216
Oct 31 17:21:43: vcpu-0| UHCI: Global Reset
Oct 31 17:21:43: vcpu-0| UHCI: HCReset
Oct 31 17:21:43: vmx| USBGL: Unhandle status -71
In der VM bringt ein lsusb nur folgendes Ergebnis:
Bus 001 Device 001: ID 0000:0000
Das ist, wenn ich mich nicht irre, nur der virtuelle USB-Hub
Wäre genial, wenn mir jemand helfen könnte.
Vielen Dank in Voraus
Beitragvon Dayworker » 31.10.2009, 19:56
Ist der Stick nicht ein USB2-Device?
Wenn dem so sein sollte, tappst du vermutlich in die alte USB-Falle des VMserver1. Der 1er unterstützt ja nur USB1.1 und bekommt Probleme, wenn Host und Device eine schnellere Sprache sprechen. In dem Fall sollte ein USB-Hub die Lösung bringen.
Beitragvon e-e-e » 31.10.2009, 21:28
ich hatte gehofft, dass der Stick auch USB 1.1 kann, habe aber keine Angaben dazu gefunden. Dann werd' ich es mal mit einem Hub versuchen, vielleicht habe ich ja Glück.
Beitragvon Dayworker » 01.11.2009, 00:28
Der Stick selber kann vermutlich auch USB1.1, wenn er an einen USB1.1-Port angeschlossen ist bzw auch die Order zum Runterschalten bekommt. Leider sieht der Stick einen USB2-Port und weiß nichts von der langsamerer USB-Unterstützung im VMserver1.
Falls du keinen Hub zur Hand hast, sollte es testweise auf dem Host auch reichen, USB2 zu deaktivieren. Dann weißt du zumindest ob der Stick prinzipiell auch langsamer könnte oder er seine Funktion wegen der Bandbreitenbegrenzung einstellt.
Beitragvon e-e-e » 01.11.2009, 10:21
ich habe nun mal testweise die IPCop-VM auf mein Netbook mit VMWare-Player geschoben und siehe da, mit USB 2.0 erkennt der Cop zumindest laut lsusb den Stick:
Bus 001 Device 001: ID 000:000
Bus 001 Device 002: ID 12d1:1001 Huawei E620 USB Modem
Bus 001 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Eine Internetverbindung ist aber immer noch nicht möglich. In der /var/log/messages ist immer noch ein
Failed to open /dev/ttyUSB0: no such Device
vermerkt, obwohl die Gerätedatei vorhanden ist.
Die im IPCop-Forum empfohlenen Änderungen der /etc/modules.conf:
alias char-major-188 usbserial
options usbserial vendor=0x12d1 product=0x1001 maxsize=8192
habe ich natürlich ausgeführt, aber die Jungs dort haben aus grundsätzlichen, teilweise auch nachvollziehbaren, Erwägungen etwas gegen virtualisierte IPCops und deshalb komme ich dort nicht weiter.
Ein paar Denkanstöße würden mich schon weiterbringen.
Vielen Dank.
Beitragvon Dayworker » 01.11.2009, 12:58
Was hast du denn als Host-OS? Kannst du dort vielleicht das Gerät auf Serial mappen und dann per Serielle Schnittstelle in die VM hieven?
Eine andere Möglichkeit wäre auch, den Stick auf dem Host einzurichten und als Nic per Bridged VMnet0 in der VM zu mißbrauen.
Das Problem bei der ganzen Sache wäre dann allerdings noch, ob der IPcop überhaupt mit solchen Geräten funktioniert bzw schon Treiber dafür mitbringt. Wenn ich mich recht entsinne, wird aus Größengründen ja noch auf einen Kernel vor 2.6 gesetzt. Was sagt den das Forum dort zu dem Stick? Könnte, müßte, sollte oder läuft?
Beitragvon e-e-e » 01.11.2009, 13:44
im IPCop-Forum berichten mehrere Leute von erfolgreichem Betrieb.
Da ich mein Suse 10.1 ausschließlich als Host-OS für VMs nutze (ähnlich eines ESXi), und alle eigentlichen Aufgaben in den VMs erledige, möchte ich nach Möglichkeit den Stick nicht in das Host-OS einbinden, abgesehen davon, dass ich noch nie Schnittstellen umgemappt habe und mir da erst einmal das Knowhow fehlt.
Beitragvon Dayworker » 01.11.2009, 17:07
Okay, versteh ich. Mach ich ja auch nicht anders...
Haben die Leutz das mal beschrieben, wie sie den Stick zum Laufen brachten?
Beitragvon e-e-e » 01.11.2009, 18:07
ja die Tipps von den Leuten im IPCop-Forum habe ich alle durch, leider ohne Erfolg.
Beitragvon Dayworker » 01.11.2009, 19:18
Kannst du das irgendwie in Kurzform wiedergeben? Vielleicht fällt mir was passendes bei VMware ein.
Beitragvon e-e-e » 01.11.2009, 19:48
als erstes habe ich die Module lsusb und moduleswitch installiert, dann die /etc/modules.conf durch diese beiden Zeilen ergänzt:
und die /etc/usb_modeswitch.conf an den Stick angepasst:
# Huawei E169
# Contributor: Dale Lane
DefaultVendor= 0x12d1;
DefaultProduct= 0x1001
# choose one of these:
;DetachStorageOnly=1
HuaweiMode=1
Nach einem depmod -ae und reboot leider keine Änderung.
Dann die Zeile:
gegen
alias char-major-188-* usbserial
getauscht, aber auch ohne Erfolg.
Ich habe auch den Wert für maxsize mal halbiert.
Ein lsusb in der VM ergibt:
Anscheinend alles OK, aber in der /var/log/messages habe ich immer folgende Fehlermeldungen:
Failed to open /dev/ttyUSB0: No such device
Ich habe über das Web-GUI bei Einwahl "Modem" eingetragen und als Authentifizierungsmethode "CHAP" mit einem Passwort, denn das hat er verlangt (die Passwortabfrage des Sticks/Karte habe ich aber vorher auf einer Win-Büchse deaktiviert).
Ich bin am Verzweifeln dran. :twisted:
Beitragvon Dayworker » 01.11.2009, 20:24
Kann es sein, daß der Stick noch seine FW, vergleichbar den DVB-T-Sticks, geladen haben will?
Ansonsten werd ich mal ne Nacht drüber schlafen oder es fällt jemand anderen noch eine Lösung ein. ;)
Beitragvon e-e-e » 01.11.2009, 21:26
naja, Firmware gibt's bloß für Win, aber in der /etc/usb_modeswitch.conf ist der Abschnitt für den Stick schon vorhanden und muss nur noch aktiviert ("entauskommentiert") werden.
Mit diesen Einstellungen, scheint er dann auf Blechbüchsen zu laufen. Ich bin mir über die Einstellungen am Web-GUI nur nicht sicher.
Beitragvon continuum » 02.11.2009, 02:05
warum machst du aus dem stick keine normale vmdk ???
Beitragvon e-e-e » 02.11.2009, 06:52
Hallo continuum,
das ist kein Speicher-Stick, bzw. nicht nur, sondern hauptsächlich ein O2-UMTS-Modem, und nur auf das Modem kommt es mir an.
Beitragvon continuum » 02.11.2009, 12:39
Ach so .
Beitragvon Dayworker » 02.11.2009, 20:51
Was sagt denn die restliche Linux-Welt zu dem Stick? Läuft er da problemlos?
Vielleicht stößt du auch auf das Dual-Mode-Problem des Sticks, bei http://blog.ml.vg/tag/huawei wird das zumindest erwähnt. Helfen könnten dir auch einge Posting bei http://ubuntuusers.de/search/?query=Huawei&area=forum
Beitragvon e-e-e » 05.11.2009, 18:32
ich wollte eine Erfolgsmeldung loswerden. Dank @Dayworker und seines zweiten Links habe ich die Kiste in die Gänge bekommen.
Mit einem:
insmod usbserial vendor=0x12d1 product=0x1001 maxsize=8192
(angepasst aus o.g. Link) hat sich der Cop sofort eingewählt.
Um nach einem Reboot das Ganze zu automatisieren, gehört diese Zeile in die /etc/rc.local.
Vielen Dank!
Beitragvon Dayworker » 05.11.2009, 20:10
Schön zu hören, daß es endlich läuft.
Die Ubuntu-Foren scheinen da auch bei anderen HW-Problemen immer etwas schneller und umfangreicher zu sein. Auch wenn das Querlesen der Postings länger dauert, so hat man wenigstens was zu lesen und ist nicht auf sich allein gestellt.
Mitglieder in diesem Forum: 0 Mitglieder und 61 Gäste
